advice on caps needed....
Mar 13, 2008 at 1:41 PM Post #16 of 17
Originally Posted by fordgtlover /img/forum/go_quote.gif
In the panasonic FMs the 2200uf 16V are 12.5mm x 25mm the 2200uf 25V are 12.5mm x 35mm.
I am no expert on these, I am a reasonable new DIYer, but as I understand, if you have the extra room, the higher voltage cap may help, but are unlikely to harm.
Farnell UK is worth checking out for panasonic caps.
I think i'll try measure them tonight and see what they actually measure and go from there. If its best to have the higher voltage, i'll go with them if i can squeeze them in.
I really hope i can squeeze the burson op amps in too!
Mar 14, 2008 at 4:17 AM Post #17 of 17
Regarding cap voltage: from what I understand, in film caps used for coupling applications, it is said that the higher voltages sound better. For electrolytics such as what you are dealing with for use in PSU applications, I generally might go up one range if I had the room, such as the 16V -> 25V. But that is only for higher safety factor, and many times is trivial as the stock cap may be higher than needed.
