obobskivich
Geez! Amen to that! Much easier to copy/reply to, too! :confused_face_2: Although, in his defense, a lot of it is Head-Fi's current forum software.
Boo Huddler!
Simple. You need capacitors so large on the output of OTL amps for low impedance phones that they're simply impractical, not even manufactured in those sizes, even. (All because of the RC circuit and the resulting cutoff frequency.) Most mfrs don't even try. I submit that's a more common reason of limiting low headphone impedance on OTL amplifiers, rather than claiming any instability in low impedance loads. The mfrs simply don't want to be accused of having an amplifier without bass, which would happen when paired with most low impedance phones.
This may very well be true - I know some manufacturers have out and out said it's a stability concern (Schiit has, for example), but it certainly could be true of other builders (what, manufacturers lying? impossible!). But it isn't like transformers don't exist. (e.g. the WA6 and the Cayin are both suitable for lower Z cans - they both cost a lot though (last I looked the Cayin had just bumped up on $900)). I know that even with some SS amps though (as I mentioned above), the manf is saying it's a no-go, but it's usually *very* low impedance (usually <16R, which is getting into speaker territory) - there's very few full-size headphones that fit into that (I can name a total of four; only one is currently in production - none are very popular). In those cases I'm thinking it's a current demand concern (the ironic part is, the four headphones I can think of, also happen to be near the top of the list in terms of sensitivity :rolleyes - just like cheap full-size amps and 4R speakers. Regardless, a cheapo-deluxe OTL is not something I'd want to play around with.
This is just my personal opinion, but I have had a pair of K701's for many years. I think perhaps the tube hybrid is among the best for proper feeding of such headphones - although I would limit the feedback involved, if possible. The high current and somewhat higher than normal output impedance from a typical tube hybrid tends to give the K701's ample current while not emphasizing the harshness that can occur with SS, super-low-output impedance amps.
I will say that I never found the 701 "additionally harsh" with pure SS amps; they did nice with the CI VHP (which is TPA6120 based). But I could certainly see someone wanting to warm them a bit (EQ, amp, whatever). I know Music Hall has a hybrid based on that same chip, forget which tubes it uses - might be worth looking at in addition to the Lyr (it runs around the same price), assuming you want tubes in the chain somewhere. Would drive basically any dynamic headphone out there with ease too.
