OK so it likes the sparse header, just not the chunk type.
Acoustic Research M2 Audiophile-Grade Hi-Res Portable
- Thread starter robfol
I have another tool to create the sparse file so will host a new image to try later
Yes, I wait to tryI have another tool to create the sparse file so will host a new image to try later
OK this should work, I have tried it on a raw image of my userdata (userdata.img) and converted it to sparse format, and flashed back and it worked.
I tested on userdata as this is far easier to recover than system so I have not tested this on system.
The new fastboot compatible sparse format of system.img (called system-fastboot.img) here:
https://1drv.ms/u/s!AjIqgYlV9XYyh3zCvcWVGR5Z4jtg?e=HBpIz4
flash with:
fastboot flash system system-fastboot.img
So we are on the same page, here is my ADB folder containing fastboot.exe so we are using the same version:
https://1drv.ms/u/s!AjIqgYlV9XYyh33MkvAWf5v3X2ci?e=VgBge8
flash with:
Yes, I'll shake hands and try it out, I'll report to you laterOK this should work, I have tried it on a raw image of my userdata (userdata.img) and converted it to sparse format, and flashed back and it worked.
flash with:
If it works, it will already be rooted with SuperSU and google play pre-installed.
[QUOTE = "Nayparm, bài đăng: 15549732, thành viên: 484741"]
Nếu nó hoạt động, nó sẽ được root bằng SuperSU và google play được cài đặt sẵn.
[/TRÍCH DẪN]
tuyệt quá
Ar ar của tôi đã tăng
Cảm ơn bạn rất nhiều
[/TRÍCH DẪN]
tuyệt quá
Awesome!!!!!!!!!!!!!!!!!!
I want to donate to you, thanks for helping me a lotAwesome!!!!!!!!!!!!!!!!!!
jmills8
Previously known as bmiamihk, jmills2
Is this Vietnamese ?[QUOTE = "Nayparm, bài đăng: 15549732, thành viên: 484741"]
[/TRÍCH DẪN]
tuyệt quá
The AR Music Music Player Pro won't appear in that system image, I removed it as it attempts to install each boot as a user app anyway.
Download here and install:
https://1drv.ms/u/s!AjIqgYlV9XYyh36-_WLVSqGd9qdV?e=LD3T1i
Yes, I am a VietnameseIs this Vietnamese ?
Thanks but that's not necessary enjoy your new AR-M2
p.s. now would be a good time to enable developer options, USB debugging and connect via ADB and tick the box to allways allow authorisation for you computer. Not as essential now that we can recover but good practice.
You are a great person thanking you againp.s. now would be a good time to enable developer options, USB debugging and connect via ADB and tick the box to allways allow authorisation for you computer. Not as essential now that we can recover but good practice.
I will follow what you say
