These are the only available pics I know of for the finalized Taboo MK III:
New black top plate. You can choose at checkout whether you want 3 or 4 pin XLR's
for balanced output.If you choose 4 pin you could have 4 pairs of HP's running at the
same time. The meter's reflect the 2 EL84 tubes in the L/R output stage.
Quote from the Decware site regarding the tubes:
"The stock configuration is a 6922 (6N1P) driving a pair of EL84 or SV83 (6P15P-EV) output tubes. The rectifier is a 5U4 but you may substitute 5Y3GT, 5AR4's or the new Valve Art 274B. You can expect over 6000 hours of pristine fidelity from the included 6P15P-EV tubes. Because this amp has the Hazen Grid Mod that activates only when SV83 (6P15P-EV) output tubes are used, we ship the amp with the best mil spec 6P15P-EV's made. These are Russian New Old Stock tubes with Gold grids, extra thick glass, plated pins, and tested in your amplifier. All tubes come with a 90 day warranty."
Back left corner you can see the Speaker connections, the input RCA's, the switch for
the new Lucid Mode and the left rear Single Ended headphone jack.
Walnut base option with Audeze LCD-2.2's.
Custom white figured base option.
Taboo site link:
http://www.decware.com/newsite/TABOO.htm
There is a Youtube video on the Taboo page that shows the build.
Eric, I was thinking that it might be worthwhile for the masses if Steve would authorize you to add a picture of the Taboo as it will look in its final state. Not everyone will take the time to click through to the Decware site. I think it looks absolutely stunning with the LCDs and the Walnut base, but the ability to customize at this price point is very rare and shows how much pride Steve puts into his products.
Taboo site link:
