yay101
- Feb 24, 2013
Great! I transfered that to the team, let's see what they have to say I didn't know about the charging problem, but it could probably be solved by isolating the DAC's power input from the charging port or by including a separate voltage regulator for it.
I really understand the frustration of low output, even at max settings some devices are bately audible, especially with harder to drive headphones. Do you think we should have an amplifier that can drive 100+ ohm headphones, or would that be overkill? Also, wouldn't that reduce the quality with lower impedance headphones?
And don't worry about the DAC itself - Eve said they will use one of the top-tier chips from Cirrus Logic, so there's little to be afraid of. Although I don't understand what you meant by roll off - maybe I'm just too noob for this :$
But thank you for your input. Also feel free to join the community and have your voice heard in all aspects of the device. And to get notified in the first place when preorders begin
I would say 100 ohm should be the absolute limit, as making a more powerful amp will lead to issues depending on topology used, at the very least as you said making iems hard to find a good volume for or raising the noise floor too far.
People running big power hungry cans will likely already have a portable amp already that costs many times the sound budget of a tablet.
Roll off refers to the frequency response graph. Many cheap one chip solutions (at least have in the past) have roll-off in the audible spectrum, so you lose bass quantity and quality. Then a poor amplifier that can't drive your headphones anyway tries to push that to your drivers and you lose even more bass quantity/quality. These are easy to remedy as long as you are looking for them though.
And yeah as far as power, a simple filter of whatever method is cheapest should fix the power ruining sound issue. It's fairly well documented but I don't think there is an official name for it
