vic1890
- Mar 4, 2008
I find the plugs at the end of these cables - whether it's toslink or miniplug are unscrew-able, but the strange thing is, once you do unscrew it a bit, the actual glass thread within the cable starts sticking out nakedly and isn't reversible unless you push it back in with some considerable force (with a soft optical cloth or cotton of course).
Is there any reason for this screw like thing? - I just can't fathom why. And, assuming no scratch occurred in this process, would the signal degrade if the glass sticks out a little more than the actual plug?
This has been bugging me quite a bit.
I do realise that VDH specifically warns not to push the plugs in with force, but I believe that is more for the outer plug, and its frailty (I learnt this the hard way after my gf snapped the miniplug side when it was just two days old while it was still connected to my macbook), the actual glass thread itself, is terribly resilient - ironically.
Any other VDH optical cable owners here that can comment on this?
