Nemo de Monet
- Oct 15, 2008
I am, for kicks and giggles more than anything, intending to play around with a discrete preamplifier design from 1967 to see how well it may work as a headphone amplifier. I'm replacing the long-obsolete 2N404s with BD140s, and making a few other changes to allow the use of modern parts. One of the stranger things about the design is that it runs on a single-sided supply (I know, I know, boo hiss) - but a negative supply.
Now, they thoughtfully provided a power supply design, which is all fine and dandy, and while I understand how it works and what it does, I don't have any Zener diodes on hand, doh, but I do have a number of regulated power supplies in the appropriate voltage range. As long as they're isolated - which they are - is there any reason I can't just use a normal power supply here, albeit with the hot and ground leads inverted?
I mean, voltage potential is all relative, and "ground" is just an arbitrary concept here, right? And since it's capacitor-coupled, nothing should go terribly wrong if I cheat a little bit... right?
Crazy power aside - it feels very wrong to keep putting electrolytic caps on the breadboard with the "+" side towards "ground" - it seems like a moderately interesting design, and was alleged to measure pretty decently way back in the day....
