Originally Posted by Bigfieroman
This is where I am confused; many people are claim vastly improved sound when using an amp...this doesn't make sense. From what I can tell, most people turn the source close to or at maximum volume, and then use the amp to adjust final volume. If there is distortion in the signal, why would it not be amplified? In other words, how does an amp make a set of cans sound better, not worse?
I understand the need for an amp with phones like the Pro4AATs, they are 250 ohm. But, my computer has more than enough power to drive them to a easily sufficient volume, so I am having difficulty justifying a $100 amp purchase. I don't listen to music very loud, and after my mp3 player is delivered today, I wouldn't be surprised if it had enough power to power them to a decent volume.
My best guess as to why an amp would create better sound quality compared to a battery powered source is because of the increased voltage. Volume is increased by increasing the current, but amps start with higher voltage to achieve the same power. For instance, my mp3 player uses 1 AAA battery, unless it is transformed, it is only 1.5v, (rechargable is 1.2v). Most portable cmoy amps use at least 1 9v, sometimes 2. Is that why people say amps improve sound quality?
First of all, forget the misconception that the purpose of hifi headphones amps is just to go louder - it's about higher quality at comparable volumes.
Anytime you listen to headphones, you're using an amplifier to drive them. The amplifier could be the built-in amp from an ipod, a dedicated headphone amp, or sometimes people even use the output stage of their source as the amp. When you plug your headphones into a receiver or integrated sepaker amp, a numer of things could be happening:
1) the headphone jack is driven by a headphone amp stage built into the receiver; usually of exceeedingly poor quality
2) the jack is powered by the preamp stage of the receiver
3) the jack is powered by the power amp stage with resistors added to bring the level down
It is true that amplifiers cannot mitigate distortions from a source. However, amplifiers
always add distortion of their own, and this is often what audiophiles seek to minimize by replacing the low quality "stock" headphone amps with a higher quality one. Note that this point is sort of debatable though - some types of distortion are considered euphonic in moderate amounts, while other kinds of distortion sound awful even in small amounts.
Anyways, the point is that amplifiers sound different because they add different types and amounts of distortion to the signal. Cheap amps (usually the kind that are built in) often add judicious quantities of the bad, non-euphonic kind of distortion. Also of importance is that an amplifier will often output increased distortion when driving a load it wasn't designed (or not properly designed) to drive. Here's where we get into the need for a powerful dedicated headphone amp - low impedance headphones need an amp with high current capabilities, else the amp will be strained (and distort more). High impedance headphones require a higher voltage swing (again, else distortion). High quality amps will typically be capable of large current and voltage swings, keeping distortion low over a wide rage of headphone impedances. The output impedance of the amp also affects distortion. High output impedance will cause distortion, but the quick fix (global negative feedback) itself is considered to cause very non-euphonic distortion. There are many design considerations to an amp that all affect the sound.
A single transistor or opamp can't come close to doing the job right, which is why high end amp design is complicated and why the cheap built-in amps sound like crap.
Sometimes you'll see people chain a higher quality amp after a lower quality amp stage, ie: using a dedicated headphone amp from the ipod headphone jack. At first such an arragnement seems counterproductive - why would you want to add the distortion from two amps into the signal chain - however it's not necessarily as bad as it seems. By feeding the ipod amp into another amp, you're presenting the ipod a different load than that of a headphone. Typically, the input impedance of an amp is very high (10,000 - 100,000 ohms, compared to 32 - 300 for headphones), which is easier to drive (meaning lower distortion) for many preamp and headamp stages. Same with people who are using their sources (ie: soundcard) to directly drive headphones. By adding a dedicated amp, they take the burden off the source's output stage so that the overall distortion goes down (or becomes more euphonic
