bhima
Hey all,
So I'm considering making the jump to the Schiit Magni amp as the E17K might not be driving my new AKG K7XX to their potential (Have to set the gain to +12db, volume up to around 80% to get it to a decent listening level). Sound is good, but it doesn't feel as spacious as I think these headphones can go.
So my first question is: Would a better Amp help to increase the space/soundstage if the headphones aren't getting quite the juice they want? Is the E17K powering these headphones properly? (E17K is 200mW @ 32OHMS, I think the K7XX are 62OHMS)
If the answer is that a beefier amp will make a difference, my next question is:
Can I connect my Fiio E17K as a pure DAC to the Schiit Magni Amp? If so, how? There are 4 inputs on the Fiio E17K: USB, Coax In, some other 3.5mm jack in the middle which makes no sense to me (possibly the aux), and a headphone jack.
I'm not sure I can connect the E17K as a pure DAC, likely will have to connect the headphone jack to the Input on the Magni via 3.5mm to RCA (making the E17K act as a pre-amp of sorts). Not sure this is the ideal way to do it though. Any help would be appreciated, thanks!
