Originally Posted by Nubster /img/forum/go_quote.gif
So if the computer can act as the DAC, why get an external DAC? I am guessing that the analog signal coming from most computers will not be the best and the external DAC with refine those signals making them better to listen to?
Not quite. The biggest reason is that computers have a huge amount of RF noise and garbage inside.
The biggest offender is the power supply. Computers use what's called a "switching" power supply instead of a "linear" one. I won't go into details, but a switching supply switches on and off rapidly to produce the power the computer needs. Switching electricity on and off with coils, wires, etc. is an excellent way to throw off RF (radio frequency) noise. It's much the same way that radio transmitters work. This means there's a bunch of radio waves going around inside the computer. [As a footnote, switching power supplies are a good thing. They're lightweight, inexpensive and hold up. If you used a linear supply in a computer, it would probably add another $300-$400 to the price of the machine as well as another 25 lbs. of weight.]
Soundcards don't have RF shielding. Neither does a sound chipset on a motherboard. Yes, you can put shielding on a card. However, locking out RF is a very, very tricky business. Have you ever tried to make something watertight, only to find water getting in again and again? RF is like that. Except you can't see it coming in, like you can see water. It reflects off things and gets in through the tiniest cracks. RF is a total pain in the ass to deal with. I'm also a radio guy - I have an amateur license - and a big part of the tests and operation of radios deals with RF.
The upshot of this is that it's very, very difficult to keep the computer's RF hash out of the signal you're listening to. The noise isn't bad enough to be noticeable from cheap computer speakers, and probably not that bad through mid-fi speakers, either. But when you hook up a high-end headphone, that's highly sensitive, and put it maybe 1-2cm from your ear, you will hear the noise. The RF pollutes the signal with distortion and hash.
This is the point of an external DAC. When I ran computer-as-source, I liked Toslink. RF won't conduct through an optical cable, so that was the end of most of the noise. You can run coax, too, but I liked optical.
I started out with a computer-as-source setup. It was pretty good, but a deal came up where I got a Sony SCD-CE595 for $60 or so refurbished. I was interested in SACD, so I gave it a try. Wow. Much better than the computer setup, and only $60. Later that year I became curious about vinyl. Found a used Rega Planar 3 in town for $200. Wow! That was even better! So, between SACD and vinyl, the computer rig idled. Then I gave that computer to my Dad when his computer died and ended up selling my DAC/amp.
I haven't missed the computer rig. And it only cost me about $600 (had to buy a cart, phono stage, etc.) to make the jump into SACD and vinyl. I paid about $500 for a used Singlepower PPX3, so that setup was about $1,100. The computer and DAC/amp ran just about $1,100, too. But the vinyl/SACD/tube setup was much, much better. So good the other setup gathered dust.
Anyway, my point is that you don't have to spend a fortune on the "good" stuff. You just have to choose carefully and buy used whenever possible. You can have terrific sound on any budget.
