Kaere
- Aug 2, 2014
I want one!!! Where can we buy it?
I need to crank the volume knob to 12 o'clock!
And? That would mean you still have tons of gain left over but better control over it.
Just FYI, if you're thinking of using CalyxM HO as LO, better don't. While the SQ is fairly good, it lacks the oomph.
For comparison, with QLS QA360 line out, I just need to turn the volume to 9 o'clock on my balanced dynalo. But with CalyxM, I need to crank the volume knob to 12 o'clock!
I am trying the M as a line out to feed my newly arrived GS-X mk2 and HD800. I am quite pleased with the results. The GS-X mk2 and HD-800 are highly revealing and the M is holding up pretty well as a home source. However I am getting the best results playing from the internal memory and SD cards. The USB DAC function is comparatively distant and lifeless. It's too bad because it would be much more convenient to operate from Foobar.
What a wonderful amp, congrats. I am extremly pleased with calyx, I use it far more than HUGO as it is just more easier. I just hope they can push the battery up to few more hours.
Hopefully they'll add ISO and CUE support, proper folder browse and longer playback time with future firmware.
I think those the only things that are lacking from this DAP.
