AmberOzL
- Dec 18, 2012
D&A had better shift themselves and get the M released internationally, quickly, or their party will be over before it's begun.
+10000.
Look at the tall part of the player where the volume control is and compared to the AK100, it's more than 7mm. I don't think I can fit the AK120II in my pocket except if it's cargo pant pockets.
Groovers and Qobus is iRiver's bet that both will take off, for me it's a non-event as I buy all my stuff from my PC and never from a smartphone and definitively not from a lone player. I would use the streaming facility though because I keep all my music on my home server, that's more attractive to me. Home wireless is cool, I used it once from my iPod touch which I sold and really loved it but was very buggy so hopefully with higher wireless modem speeds we should have a better continuous signal.
Sorry to dash your hope but transforming a dual DAC to balanced outputs requires circuitry to phase shift the outputs and then recombine them so it's gonna be very doubtful they can achieve it without major surgery plus the connector will be an issue, something gonna have to give, the DX90 case is anything but packed and no more openings unless they drill a hole. They will most likely have to use one of the existing connector holes so you'll loose some features on the way, which one? Hard to say.
Other than that, though, $419 for such SQ is almost unbeatable right now.
I concede that the new AKs will have a more discrete approach to the amp stage, and that is nice, but is it nice enough to justify charging 3-4 times as much as a DX90?
I don't know for sure (I'm no electronics expert) but I suspect the DX90 will be a very easy mod to balanced output. The DIY-ers will post about it soon, just wait a while...
I don't think you have to worry, the size is still smaller than iPhone 5s, though almost 2x thicker
Yep, the wifi streaming is one of the highlights IMO. The attractive part of Groovers is that they have a number of 24 bit files which i can't find elsewhere, and also the convenience of being able to get new tracks when you are outstation or something.
Gracky, thanks for impressions, really curious. Would you tell if you use high-end at home and which one. I am in the same boat and when you refer to high end vs luxury i am curious to see from what corner you coming in on this. So no doubts about your findings but need understand if we talk the same language as i will need to make my choice blindfolded since in Europe no chance to try out before purchasing. Thx
I had used old B&Ws, Krell, McIntosh and Meridian for a long time. For some years I couldn't use speakers and that is why I had to enter the head-fi world. I think my definition of being neutral will be similar to the B&W sound, no excessive highs, firm but not stiff bass, deep sound staging.
What's your feeling about the purchase, have you had time burning the player and do you feel the price is right for the sound you heard so far?
$5k? That good?
Too early to conclude, but I had a complex feeling about the situation of the audio market especially after the recession. If I were the D&A president, I'd move the firm to the US, buy an inactive highend brand, and sell M for at least $5k.
