roadtonowhere08
- Mar 6, 2004
What HS do you have on the CPU. I recommend a Thermalright cooler if your CPU is that hot. Also, look into getting a GPU cooler that exhausts the hot air outside, like the Arctic Cooling GPU coolers. The metal that you cool with and the airlow pattern you use is every bit as important as raw CFM's.
To give you a reference, I have an AMD Athlon64 3000+ and a Radeon 9800Pro. The CPU is cooled with a Thermalright XP-120 and the GPU is cooled with an Arctic Cooling VGA Silencer (Rev 3). Now, I will admit, I have not a clue as to the temperature of my GPU, but all the hot air is being directly expelled out of the case instead of being recycled. My CPU maxes out at 49C with a 120mm Nexus on it (23db and roughly 37cfm). My computer is a slight breeze and my temps do not get hot.
