Thank you for your reply!The tips with the arrow in your photo are Kbear 07's. The ones with the smaller bore and bluish silicone are Kbear 08's. Both are clones of Acoustune tips. I don't know what the clear silicone are. Anyway, those are the same tip selection that I received. The 07's should have a little less bass with open mids and treble compared to the 08's with the smaller bore which should have a bit stronger bass. The 08's can tend to be a bit brighter despite the stronger bass. I think they may provide a bit more V-shape but it depends on your ears and the iem. I like the Kbear tips, I use them on a couple other iems. With Timeless I do get a bit better seal with Spinfit CP100's which may have a hair less bass. I think I very slightly prefer the Kbear 07 with Timeless but I'm using the Spinfits as of now because of the seal and comfort.
Just to confirm, are these the 08s?
PS1: I will also use the SpinFit CP100+ , as soon as they will arrive from AliExpress. They are delayed
PS:2 I, as well, have just ordered the KBEAR Rhyme, even though 1) I already have the KBEAR 16 Core and 2) I am planning to use my Timeless with my FiiO UTWS5, which will arrive next week, exclusively.
