iconoclast hero
- May 4, 2009
ok... how should i post them?
Originally Posted by olblueyez /img/forum/go_quote.gif Swiftech RheoStat Fan Speed Adjuster Products Model: RH070 [RH070] : Performance-PCs.com, ... sleeve it and they will come Drill a hold somewhere in the case and mount this. They can put smaller connectors on it too if you like. |
Originally Posted by iconoclast hero /img/forum/go_quote.gif Adjusting the speed of the fan would help to attenuate the noise of the fan itself. The problem is the vibrations produced by the fan. When the fan is isolated from the case, the noise isn't a problem. It is possible that reducing the RPMs might be effective in reducing the objectionable noise... Unfortunately depending on how much reduction in speed was required the fan might not function effectively. I really think that the best way to handle this is to find some way to dampen and isolate the vibrations of the fan from the case. I just need to figure out how best to do it. If it was possible to neatly cut vents in the top of the case, I think that would help, but I have no idea how I would go about that. |
Originally Posted by zeroibis /img/forum/go_quote.gif Why have him adjust it himself would not using a temp based device be more reliable. |
