Jon L
For him, f/1.2 is a prime number
- May 20, 2003
I'm having a tough time finding some quiet 60 mm fan, 15 or 25 mm depth. There's precious little info even at silentpcreview regarding 60 mm fans. I'm trying to replace a noisy "Superred" 60mm x15 mm fan.
Anyone have any real-world experience? SilentX, ADDA, Panaflo, Papst, etc without breaking the bank?
EDITED WITH MORE INFO
It's actually the internal fan for JVC D301 USB digital receiver, the black one in the middle of the component. Currently, there's a 15 mm depth fan but there is more room depth-wise. I can't really go larger (80 mm adapter) b/c it's mounted on a metal bracket that's bolted to chassis bottom. I can't find any specs on this "Superred" fan on the fan or on the web. It's 60x15mm, and it gets quite loud, so I'm guessing 12-16 CFM isn't going to cut it.
Model: Superred CHB6012AS(E) DC12V 0.06A.
