boomy3555
- Sep 26, 2008
Th Best Answer would be to cut off the cable about 4" below the twist on 2.5 that snaps into the cans. The solder on a 3.5 mm female TRS jack and then a 3.5 TRS Plug to the other exposed end of the existing cable. Then you could connect any cable to it. Google 2.5mm to 3.5mm cable and you will find a plethera of aftermarket short adapter cables but they will not lock into place. they will be at the mercy of the natural tension of the 2.5 plug.
