Kirosia
- Sep 24, 2003
I think this is all part of the Great Evil Apple's sinister plan to get people to buy Bose Triports. If anyone has any evidence to the contrary, I'm ears wide open.
Originally Posted by Ploop just another reason not to buy the iPod. Their are other choices you know. Creative Vision:M Toshiba Gigabeat S (those are the ones with video). Plus the iAudio X5, Zen Sleek (or Photo). The 5G iPod sounds nice (yall probably have amps) but what the point of buying a portable player when you need to get a dock to even use it safely. |
Originally Posted by dpippel So based on nothing more than a bunch of posters freakin' out, everyone's headphones are gonna explode and Apple has become the Microsoft of DAPs. |
Originally Posted by sxr71 Anyone who uses the headphone out of their iPods should test for DC offset. Just take any old mini-mini cable and two wires connected to a sensitive LED (a dollar at Radio Shack) and bare on the other side. Connect one end of the mini to mini cable to the headphone out of the iPod play music at maximum volume. Touch the bare end of one those wires to the long metal section closest to the base of the exposed plug and the other wire to the middle metal section and then change that wire to the end metal section of the plug. Then you have to have switch the wires such that the wire you used on the two outer sections of the plug is now touched to the long metal section closest to the base of the plug and the other wire is now tested on the two smaller metal sections. If you see the LED light up at any time during the four combinations you tested you have a problem. I wish I could draw it out and I hope you understand how to do it or that someone else explains it better than I can. I urge you test out your iPod it's pretty simple. |
