Pariah1
- Jan 8, 2009
Thanks to another thread (that I feel got too long and that I have changed my mind on some things since my OP), I am down to these 4 cans to choose from:
Grado 225i, 325i
Denon D2000
Alessandro MS1
I'm leaning heavily towards the 225i's and D2000.
I will be pairing the cans (for now) with an av123 X-Head amp feed by a Dac Magic with FLAC files. Later I want to try a budget hybrid amp like a Starving Student Mini Millet or Head-Direct EF2.
I will be using these mostly for rock (mostly classic rock to 80's) and metal. I like a bright, lively, forward, detailed, accurate, clear, articulate, etc. presentation with good PRaT or quickness/speed. I LOVE mirco detail and instrument separation--hearing the layers in and between the instruments and lots of the nuances of the sound. Imaging is nice too, as is a decent soundstage, but I have my speakers for that and I want more a more focused sound in my cans. My favorite two groups are Rush and Queen, especially their 80's material (I like my synths!
) to give you a sense of the type of sound I like. But I also like more acoustic driven rock too (Jethro Tull, The Bealtes) and heavy metal/prog rock (Metallica/DT), so not everything bright, upbeat, and fast!
My fear with the Grado's is that they will be too bright/harsh (especially with the X-Head amp that is bright, if not crisp, thin/lean, or dry), and that the Denon will be not as good for rock/metal and maybe a bit "boxy" besides being more laid back. The Grado's also have the comfort problem, the Denon does not.
Price isn't really a factor as I can get all for around the same damage, new or used.
What do you think is best for my preferences? I'm going from a Senn HD 595 (my first real can) btw, and it isn't bad but I find it's mids too recessed or laid back, it's bass lacking (I'm not a big basshead but it's really thin if somewhat articulate, but otherwise nonexistent) and it's highs to be lacking "sparkle" or extension and detail yet are a bit silibant sometimes.
TIA!
Grado 225i, 325i
Denon D2000
Alessandro MS1
TIA!
