3.5mm se. 2pin cable that reduces brightness and treble spikes?
post-15467908
Post #2 of 13
technobear
Glastonbury, UK
Glastonbury, UK
No such thing exists.
If you don't like your source, change it.
If you don't like your earphone, change it.
post-15467938
Post #3 of 13
Chris Kaoss
Bavaria
Bavaria
How about a little EQ instead of dropping your coins out that way?
What's your source and your headphone?
post-15467969
Post #5 of 13
Chris Kaoss
Bavaria
Bavaria
OK. ^^
I'd recommend to use the excellent features of the RME to lower the highs.
It's a marvelous dac to play with.
No additional cable needed, except for look and feel. :L3000:
Tbh, if you don't like the sound signature of the U18T, i'd have a look at another earphone, espacially in that price range.
Imo, i wouldn't buy a headphone that doesn't fit my preferred needs out of the box.
There're much lower priced iems out there to play with, i think. :wink:
Reactions: SupperTime
post-15468024
Post #6 of 13
SupperTime
usa
usa
OK. ^^
I love the u18t, it's jsut that I have some recording that are poor and I can't find a quality copy to download. So I do with these. And their treble areas are poop. I also has a slight sensitivity to treble but with quality recordings I'm totally ok
post-15468051
Post #7 of 13
Chris Kaoss
Bavaria
Bavaria
Great.
It's time to play with your beautiful dac, i think. :)
There should be plenty of option to get rid of the annoying highs.
post-15468060
Post #8 of 13
SupperTime
usa
usa
Great.
There is haha, I just don't know what I'm doing. I also would like less sub bass and bigger mid bass inpact with select recordings, but then again, I don't know what I'm doing, I've played around and I just seem to distort things and ruin stuff
post-15468066
Post #9 of 13
Chris Kaoss
Bavaria
Bavaria
post-15468077
Post #11 of 13
Chris Kaoss
Bavaria
Bavaria
My pleasure. :wink:
Hope you'll have many hours of increased listening satisfaction.
post-15468168
Post #12 of 13
baskingshark
Jabberwock Island
Jabberwock Island
Anyone know of any under 300 usd?
Cables causing a change in sound signature is a very controversial topic in audiophiledom. One camp says measurements don't show any differences, whereas the other camp claims they can hear minute differences. I've seen flamewars start on threads cause of this.
Well I'm in the latter camp that does believe in cables changing the sound signature a tinge, but it's not light and day differences, more of subtle changes. TBH, you will get greater changes in sound signature using different ear tips (foams tend to lower treble and wider bore silicone ones tend to increase treble a bit), different sources, EQ, and even some mods (like putting foam/tea bags in the IEM nozzle) or knowles filters/damper mods. Cables are the last thing I will go for to reduce brightness and only after trying the above options.
FWIW, in general I find pure copper cables do decrease the treble a tinge, whereas pure silver ones may increase brightness a bit. I usually buy 8/16 core NiceHCK copper cables for this purpose, it retails around 10 bucks online.
post-15468269
Post #13 of 13
artpiggo
Bangkok, Thailand
Bangkok, Thailand
effect lionheart?
