3.5mm Lightning cable
Dec 9, 2012 at 9:28 PM Thread Starter Post #1 of 7
georgelai57
Hi,
Does anyone know of whether any third party has made an Apple Lightning-to-3.55mm cable yet? Thanks.
Dec 9, 2012 at 11:08 PM Post #2 of 7
Hi,
Not sure, but Apple is the only one who makes the chip that goes inside the 8-pin lighting cable that allows the cable to work.
Just checked around, looks like the only cable made for the 8-pin lighting connect, is for a USB (digital) port, no analog cables.
Dec 10, 2012 at 4:59 PM Post #3 of 7
You can buy the 30 pin adapter and then use any line out cord that you have for a 30 pin. The only issue is then that adds a lot more height to the phone.
Dec 17, 2012 at 7:41 AM Post #4 of 7
lightning to mini usb > mini usb to 3.5mm>  amp/dac    so far its about all i have been able to figure out not sure if its even worth the trouble...? 3.5mm to 3.5mm > amp/dac is the only option i am willin to go with at this point ... hopefully the  lightning to 3.5mm comes out soon or something
Feb 15, 2013 at 8:28 PM Post #5 of 7
Hi,
I thought the Lightning dock was digital only, in which case a line-out cable is impossible.
