xnor
- May 28, 2009
Sure, 24 bits during multitrack recording is obviously advantageous but recording at higher sample rates does not necessarily mean better sound.
So you apply less effects to 24/96 files and say it sounds better than heavier processed files that happen to be sampled at 44.1 kHz? Isn't that dishonest to the customers?
Also, check if your nonlinear plugins/devices are broken (for example if they don't oversample).
That reminds me of the files that Linn offered for format "comparison" quite some time ago. The 24/96 files had a clearly visibly different waveform (my guess was less compression, EQ ...) than the 16/44.1 file. The different processing is what made the 24/96 file sound better, not the delivery format, but of course the 24/96 files are more expensive. Is constraining oneself to do less processing so hard that it justifies a higher price?
When recording in 24/96 we are at mix down using less equalization and the reverb tails just sound so much better,than at 16/44 or 24/44.
