Davesrose
- Oct 20, 2006
It is the same with 4k 1080p picture. It actually compresses to a smaller 1080p file than 1080p does, invented recently, 1080p that is recorded at twice the definition (4k) has a cleaner downscale and a smaller lossless algorithm compression due to the wider range of pixel colors, especially when taking HDR into the mix. A case of compressing a more complete information index into a small size rather than not being able to compress files too well because of the
(Genius) earlier who suggested entropy causes a problem. He was wrong and totally missed my point this is a better way to explain my philosophy on compressing audio.
This is utterly false. I was specific about blu-ray and UHD standards in a previous response to you where you didn't understand the difference between an uncompressed audio CD standard vs CD containing compressed mp3s. It seems you're trying to understand video codecs: formats for compressing video to a smaller file size. 1080P blu-rays are encoded in MPEG-4 H.264. A good video encoding program will let you specify properties such as 2 pass encoding (where the software first goes through the video to analyze and then finalize a variable bitrate that's high enough to maintain quality, but small enough to save disc space). If all things were equal with a 1080P resolution video compared to a UHD resolution (and barring frame rate or color depth differences), the 4K video takes up 4 times the data. H.265 was implemented with UHD so that UHD movies could still fit on a blu-ray (with up to 100GB storage). If you compress a 4K movie with the h.264 codecs common with HD, you still wind up with a much larger file size. If you encode a 1080P movie in h.265, you wind up with a much smaller file size than UHD.
