[1] by the comment your not trying either it's amazing how much can be done on paper with no real-time hearing ... [1a] cheers to your ignorance in this.
[2] So on paper bits are bits right. [2a] Jitter does not exist.
[2b] Flabby bass or schilling highs it's the System or recording. [2c] Such little actual knowing and so much more on a parrots level and repeat.
1. Yes it is. Digital audio was invented "on paper", one specific paper to be precise. However, you need to be careful here, there's an old English saying, "those who live in glass houses shouldn't throw stones". How much "real-time" hearing/listening do you have? Almost certainly less than me or some others here!
1a. No, cheers for yours! Again, you need to be careful, you don't know who you're talking to, some of the people here know far more than you and calling others ignorant when you are the one with far less knowledge will just make you look foolishness!
2. On paper AND in a digital audio system.
2a. Where did you get that from? Jitter always exists but today's technology reduces jitter to such low levels that amps/speakers cannot reproduce it and even very cheap modern DACs can do this. If you have a jitter issue that's actually audible, then as already stated, you must have an incredibly poor/faulty system.
2b. Correct, it must be either the system or the recording. If you're getting a flabby bass or shilling highs on all your recordings, then either you ONLY listen to poor examples of certain music genres or you have a poor system (or a good system very poorly setup).
2c. You are the one "parroting", you're parroting audiophile myths and clearly have little actual knowledge. Did you read the OP? If so, what part of it didn't you understand?
Any same track at 24 shows a much lower noise floor ...
Sure, under certain circumstances some tracks will show a lower noise floor with 24bit when viewed on a spectral analysis. However, you should take your own advice and try listening; the noise floor of 16bit is below the noise floor of almost all recordings, below audibility at any reasonable listening level and your system cannot reproduce anywhere near 24bits anyway. Did you not read the OP?
If I posted it it's real try it or shut up about how it can be.
Firstly, you obviously have little idea of what's real and what isn't, if you did then you wouldn't be listening to music recordings in the first place! And secondly, the "glass houses" saying applies again, some of us HAVE tried it, many more times, for many more years and under more stringent conditions than you. So you're making yourself look foolish as in comparison YOU haven't tried it and you should "shut up"!
[1] Did you read my post of my room so I sound like I'm nuts hahaha
[2] An open mind is nice it's about hearing it not a paper telling us it's perfect.
1. Yes, unfortunately you do sound like you're nuts. Why would you built a room with such poor dimensions for sound reproduction?
2. Firstly, an open mind is nice but only about certain things. Surely it's only "nice" to have an open mind about things that are not already quite certain? For example, is it it "nice" to have an open mind that the Earth is flat or that gravity doesn't exist? Secondly, having an open mind should surely apply to you too, shouldn't it? Shouldn't you have an open mind to well known and demonstrated facts, even if they conflict with your beliefs?
Time and again we have audiophiles come here, try to tell us what's real and what isn't and that they have better hearing and better equipment than us, ALL of which is FALSE! I am used to a system that's almost certainly far better than yours, I have trained listening skills and I listen to recordings far more than you do (and so do ALL my colleagues), so those parts of your typical audiophile argument are false! As to what's "real", there are people here whose job is to make the unreal seem real (to human hearing perception), so who is the person demonstrating ignorance here?
G
