barleyguy
- Apr 28, 2009
From a technical perspective, I agree this is not accurate. But from a practical perspective, this is really what happens between a 16-bit and 24-bit version of a recording in the real world. Things are recorded and mixed at 24-bit. But when a 16-bit version is released, compression or limiting is used, which effectively removes the top 8 bits. When 24-bit releases are done, the top 8 bits are left intact, so what is given is a recording with more dynamic range.
What you are asking for is either a 16-bit recording mastered without compression, or a 24-bit recording that is compressed to 16-bit standards. Neither of these happens in the real world. For a technical comparison between the two formats I understand why you're asking. But if you want a comparison between what is released in 16-bit and what is released in 24-bit, that's exactly what is being given.
Originally Posted by leeperry /img/forum/go_quote.gif oh ok..so it's not 16bit either so this indeed seems to be far from a 16/24bit genuine comparison?! it'd appear to actually be a 14/24 bit comparisons w/ different masterings....so please keep us posted whenever you will be able to provide us w/ genuine 16/24bit files dithered from the same exact 32float source w/ the same exact mastering/dithering algorithms. that's what annoys the OP of this thread, companies push 24bit....but the mastering is much different, and in that specific case it's even worse because your 16bit file has been HDCD encoded so it's not even true 16bit |
