We also don't need flippant remarks that have absolutely no bearing on the conversation at hand. It's uncalled for and unneeded and comes across childish and pity. Why not just simply argue your point well and politely? Let's all be nice.
Now now, that was an example of music that responds well to dither, did you actually read my reply?
1. What point, the point you've just invented to support your ridiculous argument? YOU are the one who quoted that dither "prevents non-linear behavior", where's the addendum or caveat to that quote which states: "except in the case of transients"? There isn't one, you've just made it up! Dither prevents non-linear distortion period, nothing excluded, Duh!
I'm sensing you're all riled up about this for some reason and didn't actually read my post properly.
Perhaps you should have a think about the mechanism, dither can only span those quantisation gaps over time,
time a transient may not have.
You appear to be disputing a mathematical fact.
3a. As dither prevents non-linear behavior, then with dither we have linear behavior and therefore the waveform is perfectly accurate.
You see this is where I'm disagreeing with you, dither can only work over a number of samples because it's a statistical method.
I suspect the problem is that you haven't reviewed many digital waveforms close in and seen how much each point counts. Take the old Genesis 'Lamb Lies Down' album, very dynamic, plenty of very quiet parts where dither is really important for 16bit due to the inherent lack of resolution. The 'perfectly accurate' you speak of is a statistical measure than cannot apply to the exact shape of one-off transient events, only in general will the waveform be considered accurate. E.g. in a periodic waveform you can look at a dithered digital cycles, superimpose all the cycles and averaged together they are indeed accurate, but individually they still have to obey the quantising levels. If therefore you only have
one of them you have no idea of knowing the true shape.
And yes, TDPF is best for audio waveforms, hurah,
Well no, again you simplify, mastering doesn't just use TPDF, shaped dither is a popular way to get a better sound from the CD format: your declaration that is 'is best' disagrees with all those mastering engineers who use a shaped dither.
He's some useful posts discussing that.
https://www.gearslutz.com/board/mastering-forum/434950-noise-shaping-dither.html
5. Right, you can't tell a difference but it's better anyway?
Who can't tell the difference?
http://journal.frontiersin.org/article/10.3389/fpsyg.2017.00093/full
http://www.aes.org/e-lib/browse.cfm?elib=18296
how on earth can you describe having 40 - 100 times more dynamic range than ever required as "barely adequate"? G
How on earth? Less hysteria, more thought please.
What makes you think 96dB covers all possible cases? I know you think it's more with dither, and for many music styles it is, especially church organ music, but as explained above it's rather debatable if dither helps short transient events.
How can you re-create a live concert sound in your house or headphones with 96dB? Or even the sound of a well hit snare drum? It seems to me you are arguing for Mid-Fi, not Hi-Fi. There are many obstacles to Hi-Fi, the ability to go to 24bit is not one of them, except perhaps here in this thread for a reason I have yet to fathom.
You also keep ignoring the fact that some people post process their digital music as which point 24bit would be rather more useful: mastering sometimes doesn't stop on release of the digital file.
And you keep refusing to explain your reasons for not liking 24bit as a 'consumer' medium, what's the deal with that? 'Because you don't think other people need it' wasn't registering here as a reason BTW.
Sooo many problems here. I'm just picking this one, because...well, frankly, I'm exhausted.
DVD videos and 24 bit audio?? Nope. Yes, the capability is there, but the disk only holds 8 gig, and if you did a 2 hr movie in 24 bit 6 channel PCM, that's over 6 gig. So, no, they don't.
Your generalisation from a single example is noted.
Yes, the capability is there would have been sufficient.
Outside the HiFi box 24bit and high sample rates are common place, as they are in any pro-audio gear (obviously), which is often IME cheaper and better than the niche 'audio' gear.
I bought a cheap USB to S/PDIF converter the other day with coax and optical out for a project, you know what, even that goes to 24bit / 96kHz.
Yet here we are, double teaming the heretic who suggests 24bit has benefit over 16bit. Doh!
