barbes
- Dec 14, 2008
Thanks for all your work on this.
I've been trying to make this work and still haven't managed it. I've got the big drive, upgraded from 80GB. I keep getting an "unsupported sector size" message at the end of intallation.
What is the "sort patch"? Which of the 64M builds should I be using?
Thanks...
Originally Posted by rmaniac /img/forum/go_quote.gif I have changed the ftp around and the above direct links will no longer work. Please go to Index of /rockbox and pick the firmware you need. Here a are some basic instructions: Everyone will need to install "bootloader-ipodvideo.ipod" pull the patcher for your OS from IpodPatcher < Main < TWiki. Then you will need to run ipodpatcher -a bootloader-ipodvideo.ipod with your ipod connected. You will then need to select a build and unzip it into the root of your ipod. I have the stock 3.2 and one with the sort patch applied. Pick 32M if you upgraded from a 30GB iPod or 64M if you upgraded from a 60MB or 80MB iPod. If you need any more help you can find me on the rockbox forums as rmaniac. The standard 3.2 release notes apply. |
Thanks...
