2010 year of portable balanced IEMs??
Dec 16, 2009 at 8:18 AM Post #46 of 68
Originally Posted by ClieOS /img/forum/go_quote.gif
For the custom IEM and the shrinking number of universal IEM with user replaceable cable, the portable balanced amp (PBA) might be a good idea. The is a few problems though:
1) Most universal IEM with no replaceable cable can't benefit from PBA easily, since recabling is a hassle and comparatively more costly.
2) There is no standardized miniature balanced connector , recable/reterminate will mean very limited compatibility, and user will need to keep swapping cable (from balanced to single-end) when (s)he want to go 3.5mm / unamped.
3) Upgrading (for both amp and IEM) will be a hassle as well, due to (1) and (2).
I would imagine PBA might get support in Head-Fi from the more dedicated few, but it will have very limited impact on the IEM market as a whole. Instead, I am more interested in Dr. Meier's active balanced ground implementation on a portable amp.
I do agree with you. I think the selling point of the balance amp is good. but for practice, it is an extra burden to have recable for it is antinomy with portable aim.
The best way to design a decent audio products is to make it more simple with more reality sound.
Dec 16, 2009 at 12:08 PM Post #47 of 68
I dont think you have been really listening, the connector mentioned is actually smaller than a mini. things must move on and we are only at this moment talking about those with removeable cables. otherwise we will be stuck forever with the mini; the balanced portable amp is a paradigm shift and an opportunity to take things to a new level. these will not replace the old way until that is what people want; for now we are talking about something for those that have the impetus to do what is needed
Dec 16, 2009 at 3:19 PM Post #48 of 68
Yeah, I do indeed.
With balanced portable amplifiers and IEMs I bet it is just a matter of time before we get matching balanced DAPs as well.
Dec 16, 2009 at 8:10 PM Post #49 of 68
Got this email from iBasso:
Dear sir,
Thank you very much for your email.
We dont have pricing for the balanced amp at this moment.
We are going to develop a balanced source for it.
Sincerely
iBasso Audio
Dec 16, 2009 at 8:45 PM Post #50 of 68
hehe nice, but of course they are; with at least one dac/amp so close to being balanced anyway and a prototyping phase for a balanced amp happening. what else would they be doing?
Dec 18, 2009 at 2:39 AM Post #52 of 68
Originally Posted by Edwood /img/forum/go_quote.gif
Portable balanced amps for IEM's make no sense since there are no real quality portable balanced sources.
You don't have to have a balanced source to have benefits from a balanced amp or balanced dac to balanced amp. I have done this on a home speaker system and it works great, though I built it with tubes and output transformers. I have been listening to a portable balanced amp and there is a sound improvement/difference.
Dec 18, 2009 at 3:39 AM Post #54 of 68
Originally Posted by charlie0904 /img/forum/go_quote.gif
ibasso is developing a balanced source? cool.
maybe it could be a future upgrade for me.
the source should come in dac form.
Dec 18, 2009 at 11:27 AM Post #55 of 68
sorry, this is not the case. you dont need a balanced source to take advantage of a differential signal path. thats a misnomer I see around here a lot too. true you cannot use a single ended dac with a regular balanced amp and get benefit, but if an amp or other circuit is designed with a SE to diff conversion circuit you will still get all the noise rejection and extra swing from that point onwards in the circuit. and that is what is going on here from what I can tell. sure if the dac is balanced too, you get that benefit from earlier in the signal path, but that is all
Dec 18, 2009 at 3:17 PM Post #56 of 68
True, the voltage swing is the thing. If the amps are designed to toss the common ground and recreate - it should be the same thing. The question is are the amp designers doing this.
For the extremely short runs noise rejection shouldn't play into the equation. If the EMI is that bad worry about your health :)
Dec 18, 2009 at 4:04 PM Post #57 of 68
ok i'll pay that, but the common modes weapon against crosstalk is not to be sneezed at either
Dec 18, 2009 at 5:41 PM Post #58 of 68
Thanks qusp, I couldn't have said it any better.
Ray Samuels
Dec 18, 2009 at 6:34 PM Post #59 of 68
as long as the balanced source is portable ( my definition of portable source will be a size no bigger than the ipod touch ), i'll seriously consider it. of course, there are many other factor to consider before i'll actually decide to get it. still thumbs up to ibasso for their foresight!
