Originally Posted by Salt Peanuts
Tyll - can you share with us what kind & how many digital inputs Micro DAC/Ultra Micro DAC will have?
There's a coax on a mono-mini plug; toslink with a full sized optical connector; and a USB mini-B connector for computer. Also on the back is our 5-pin DIN power input connector. On the front is the digital input selector switch and power switch.
Originally Posted by noseallinit
it has the one Mini Analog Input on the front? and then the USB, Optical and Coaxial on the back? any other Line Input or Output?
Yup, mini line in on the front. No input switching! You plug in the line in and it disconnects the digital and connectes the line in. On the rear the toslink and coax digital come in the same jack, so it's one or the other, and if you have a digital in and the USB in it has a preference which one it selects....sorry I can't remember at the moment. On the back there is also an extra volume controlled line out so you can hook it up to computer speakers. Front has both crossfeed and gain switches, line-in, headphone out, and volume control.
which has better SQ? the new Micro Portable Amp or the old MicroAmp w/ Desktop Module? the new internal Micro Portable DAC or the old 9 Volt MicroDAC?
Their pretty close, but the Desktop module is a tad better. Can't afford the current to run a diamond buffer portably, but we do force a little bias on the 8397 in the Micro Portable so it's running class-A most of the time unless you've got pretty high impedance headphones.
what can we expect with the trade in program?
AFAIK our normal trade in program will still be in effect, I'm not sure what it is, you can just call in or email
sales@headphone.com.
You asked some other questions, Nose, and I'm having, and going to have, a hard time getting to them for the next week or two. If Jamey doesn't get to them first I'll get to them when I'm back in the office regularly.
Originally Posted by carlosgp
Will be possible to use the Micro Portable Amp internal dac with an external amp?
Only through the heaphone jack output...which is pretty good, but I know it's not the answer you want. Sorry.
Originally Posted by jamfan16
Are there any plans for packages and pricing? If so, would they be available at the same time the amps go on sale?
We don't have particular plans at the moment, but I'm sure there will be packages. What would you like to see in one?
Originally Posted by Wakeride74
It seems some of the portables are moving towards Li-ion batteries that will power for 30hrs or so. Is this something that HR is trying to implement with the new portable line?
Yes. We are using Li-ion batteries in the new Micro and Desktop Portable. We've talked a lot about battery life with these products and the consensus is that 10-20 hours is about where we want to be. What ends up happening is we put together the unit and then turn up the biasing to make it sound better, we stop turning up the biasing when we hit the point when we're down to the minimum desired battery life.
Our assumption is that you don't really need more battery life than your player has. My feeling is most players get about ten hours, so 15 hours is a pretty safe number. But I think we're still open to adjustment here; I'd love to hear how you guys would want your amps dialed in? More battery life, but slightly reduces sound quality? Other way round? Where would you draw the line on battery life?
Originally Posted by MASantos
Tyll, I know very little about circuit design, but how is it possible to fit the max circuitry inside one of those little boxes? Is it exactly the same?
Once you get the power supply out of the box, you can go from full sized gear to our Desktop sized box. Then once you get rid of a lot of the connectors and switches you can fit it into a Micro. Remember that we use surface mount parts that are about 2mm x 5mm for resistors and caps, and about 6x6 mm for the chips, so the whole Max circuit is only maybe 5 cm x 5 cm. The bigger problem is heat...we lucked out, the Max circuits are within the limits of the unvented enclosure----it does get toasty warm though.
Originally Posted by jinp6301
is there going to be a sale for the old microdacs?
Just kind of depends on how much we have in stock when the new ones come out. Also, we think people are going to remain pretty interested in picking up the old Micro DAC as there isn't a portable one in the new line-up. So I guess it's somewhat unlikely we'll have a sale...but we really won't know untill the time comes.
Originally Posted by bradman
Concerning the micro portable, will the LyPo battery be user replaceable or will the micro have to be shipped back for battery replacement? If it is going to be user replaceable, will the battery be a custom design for the amp or an off-the-shelf item? And, as another poster has already asked, I'd be interested to no about playing times with and without the dac module and if the dac can be switched off to save power when it is not being used.
I think we'll have to do the replacing of batteries, but I'm not in the loop on that one, Jamey would have to clarify. I'll get the details on playtimes soon...lot's of questions about that. Sorry the DAC can't be switched off. It's mostly an issue of how many switches can fit on the thing, and that we use pretty expensive switches. But I've heard that comment a couple of times now, and I think it's a good one to keep in mind for the future, thanks.
Originally Posted by leftnose
I currently have a MicroDAC that I've been thinking of pairing with an amp. Will the new amps have the same footprint and be stackable with the old products?
Yes. They're exactly the same enclosure and bezel.
I'll try to get some pictures up for you, Nose.
