Tysun
NOTE:
1) You can plug any balanced wired headphone to single-ended (SE) source using an adapter. The adapter will effectively convert the balanced wiring on the headphone back to single-ended wiring, so it becomes SE headphone to SE source.
2) You SHOULD NOT plug a single-ended headphone to a balanced source using an adapter. The adapter in this case will short-circuit the balanced output in the source. It might seem to work in the short run, but you are on borrowed time as you are slowly damaging the balanced circuit on your source and can lead to a burn out of the circuit.
Thanks fellow Malaysian Head Fier, you answer has been quoted in E1DA DAC thread FAQ. This same question has been raised again and again, almost on daily basis.
