psikey
- Jul 15, 2008
Thanks for the info, just to confirm, the 2 silver litz cable you've mentioned are the same brand and model just with different plugs (2.5mm and 4.4mm)?
Do you mind sharing a link to the adapter you're using?
I'm guessing it is one without a cable, basically just a hard adapter.
For the adapter, if you move/rotate the cable's jack while its plug into the adapter and while there's music playing, do you here any noise or experience slight cut offs?
Sounds like you would also go with the 2.5mm variant + adapter (balanced connection) over the 3.5mm variant direct (unbalanced connection)?
https://www.amazon.co.uk/DD-Balance...23846&sprefix=dd+2.5mm+to+4.4mm,aps,84&sr=8-2
Yes, currently no loss of signal when rotating and normally yes on balanced vs 3.5mm SE but depends, Mogo 2 is excellent 3.5mm only.
