$1295 Aurender FLOW - portable DAC/amp with mSATA slot for up to 1TB SSD
Mar 7, 2015 at 5:10 PM Post #186 of 238
Yes,it does. Hiby can play all music files ( DSD,flac,etc,) in mSATA SSD.
I had tried with Samsung EVO 840 mSATA SSD (exFAT Formatted)
that solves all problems then!!
1TB storage for smartphone is exactly what I've been looking for.
I remember someone has mentioned that when you play music from that SSD in FLOW, it only supports 16bit 44.1kHz quality.
Is that true?? can Hiby play all files up to 32bit 382kHz, DSD 128 at their native quality?
Mar 7, 2015 at 9:04 PM Post #187 of 238
The image is DXD test file(24bit 352.8kHz) from 2L.
Sorry,I donot have 32bit 382 kHz file.
Please click on the image to see it clearly.
Mar 8, 2015 at 8:08 PM Post #190 of 238
  No need for cellphone browsers , you can access all files and folders through Hiby app.
I ' ll show you latter.
This image verify My LG Phone is unrooted.
How to access files and folder
Open Hiby app. There are two popups.Click ok on the access the usb device popup.
For Network error popup ,it will not show if your phone connect to wifi.
Swipe the screen to the right or click < , will show the scan screen.
Swipe to the right or click ...,will show you Categories menu.
Click on Folder menu,will show you all Storage drives.
Click on USBstorage1 ,will show you all files and folders in the mSATA on your FLOW.
Now I will show you how to play
Click on DXD folder ,then click on the first folder,show DXD test file from 2L.
Click on the music file , the music start to play (notice the white bar infront of
the music file and play icon on the Flow).
Swipe the screen to the left ,show you the player screen.
That's all and thank for reading this.
Mar 9, 2015 at 5:27 AM Post #191 of 238
Thanks - I finally worked out why it was not working for me before
I had to format the mSata in FAT32 using a online utility - http://www.ridgecrop.demon.co.uk/index.htm?guiformat.htm
NTFS/exFat was causing the OTG to not mount properly
Now everything works fine in Hiby as per Chart54 - dont know why his works in exFat - but that did not work for me - Only FAT32 works for me.
Mar 9, 2015 at 8:34 AM Post #192 of 238
It might be because some android phones do support only
Fat 16 and Fat 32(SD or micro SD up to 32 GB) and some
phones do support Fat 16,Fat 32 and exFat(SD or micro
up to 64 GB/128GB)
Apr 17, 2015 at 5:39 AM Post #195 of 238
I've been playing around with the Flow lately. Here's a very good combo that sounds very good to me:
Mac -> Schitt Wyrd -> Flow.
On my Mac I have Audirvana Plus using the iZotope 2x/4x/8x up-samping with optimum settings. The "flatness" of the Sabre DAC sound has been abolished by effectively bypassing the less than stellar default filters.
