oneplustwo, did SumR not provide any documentation with your transformer?
Anyway, mine is a 50/60Hz dual primary, dual secondary unit.
Primaries:
a) 115V 17VA Blk*/Wht
b) 115V 17VA Brn*/Org
Secondaries:
a) 35V 15VA Red*/Yel
b) 35V 15VA Blu*/Gry
* denotes beginning of winding (polarity)
So, for 115V AC mains:
IEC live -> power switch -> Blk+Brn
IEC neutral -> Wht+Org
IEC ground -> chassis
On the secondary side to the σ22s:
~ G G ~ = Red, Yel, Blu, Gry (either left to right or right to left)
Now, I don't know if this is indeed the very same transformer you have, or whether SumR always use the same wire color coding for custom-wound units, so don't just take my example at face value. Check the docs that came with your transformer to be sure. If no doc was supplied, you should contact SumR for clarification.
