Someone on another thread asked for details on my uncompleted B24 build so here they are. I have finished one channel so far and tested it with a very poor pair of old speakers. I am not really sure how it sounds beyond the fact that it obviously has tons of power (more than I will ever need) Unfortunately in the process of troubleshooting my other board i ruined enough of the traces that I decided it would be best to simply start over. So I bought another board and am almost done populating it. Hopefully it works ok. For the power supply I have to O22 boards that are both up and running supplied by a 30VA SumR transformer. For the unregulated power supply I have a 500VA SumR transformer and 4 15,000 mfd capacitors. With that much capacitance I think i will have to do an inrush current limiter. I have an extra solid state relay and think i'll make a delay circuit out of a 555 timer to short the caps a few seconds after start up. The entire amp is contained in a 400mm deep 5 rack unit tall HI FI case. The heatsinks are ones I bought off ebay and cut to 8 by 8 so that they will be able to both fit totally in the case unlike versions of the amp done by others.
Picasa Web Albums - Gregory - audio
One question for AMB. On my one finished/working board I mounted diodes 7-10 flush to the board. I recall reading on headwize some time ago that those needed to be mounted 1/8 above the board because they get quite warm. When I tested my amp (it was at low volume and for no more than 20 mins) the diodes did not seem to get hot even though the amp seemed to be working just find and heat was pouring off the heat sink. Should I replace them and re-adujust my amp?
For the rest of the system I am working on I have the following that are in various states of completeness:
RelaiXed preamp (i wanted to do a B22 but I ran out of cash...)
Buffalo 32 DAC
a pair three ways with Dayton RS270 for bass, a 5.5 SBacoustics for the mids, and a Vifta XT25 for a tweeter. As these are my first pair of speakers I did not want to get to expensive so perhaps later i'll upgrade to something with better drivers (hopefully I can afford some scanspeak drivers by then)
I also have an 18" Mal-X sub that will be used with the system for movies.
I will have the system done by the end of August as I am going to college in early september so I have to finish it by then....
This all started about last August when my logitech speakers died and I heard a real sound system (McIntosh) for the first time. I decided I wanted something that sounded that good. Its my first real DIY audio project, and first project that deals with AC circuits. Starting with a B24 was probably not a good idea but I have learned quite a bit. I will post more pictures when I am done.
