Dithyrambes
- Dec 8, 2014
Alright guys! Have fun with your new toys! I will just be getting a zx2, and using the rest of the money to get a Schiit gungnir multibit. Think its a better use of funds. Enjoy!
Considering the only way to get the full features of the 1Z/1A, which is support for DSD (for those who happen to have it), I dont see the point of going single ended.
Does anybody know the Vrms of sony's DAP?
Strong enough to drive HD800S/HE1000 at loud levels?
My Ak380 without Amp can not,with amp its perfect
REGARDS NOMAX
60 from 3,5 mm and 250 from 4,4
ON THE BENCH
Into our 32-ohm test load the AK380’s output was a healthy 50mW
He said Vrms not mW.
You can use a converter to yield the results:
60mW @ 16ohm gives 0.98 Vrms
250mW @ 16ohm gives 2.0Vrms
Note that AK's official spec sheets shows their power output with no load, so a direct comparison can't be made at all. However someone did measure the AK380 with a 32ohm load before:
http://www.avhub.com.au/product-reviews/sound-image/astellkern-ak380-portable-music-playerdac-review-414055
So the SE of the Sony is weaker for 60mW @ 16ohm, but the balance output would beat the pants off the AK380 standalone even if you assume less than perfect conversion (eg 250mW divided by 2 is 125mW, even if you assume 10-20% loss that's still 100mW which is double that of the AK380).
Thanks a lot from Austria.......i was hoping that this SONY DAP can drive all my OVER EARS(HD800S/HE1000)without optinal Amp,,,,,,my AK380 COPPER alone is also not strong enough....but with the AK AMP its enough Power and sounds Perfekt
NOMAX
I'll measure it folks don't worry. Give me a wee bit of time to get situated...still reelimg from z1r review.
why not try lower Ohmnage cans with higher sensitivity
Nomax if you are mainly after power and sound quality obviously get a Lotoo Paw Gold : 500 mW @ 32 ohm. Definitely will drive all your headphones.
For those who heard the zx2 and habe the wm1a....could you comment if there is a sonic difference? I just tried this qp1r and was disappointed so I'm going back to the sony house sound. On the fence what to purchase. Wm1z too far off a stretch
