spook76
- Jan 13, 2013
http://penonaudio.com/Lightning-Pure-Silver-Decoding-Cable
Is the sound quality of mojo that much better than the DAC in KSE1500...
Now that Astell & Kern has apparently fixed the issue of the 2,5mm balanced headphone out with the SP1000's, I wish SHURE will come soon with a balanced Amp module (balanced analog input). This will be a great upgrade to the KSE1500...
I may be mistaken but do you mean you would like two separate channel output from the KSE energizer?....
NO NO I wish that the KSE Energiser also had a balanced analog INPUT.
If an energizer or amplifier is well engineered and designed I was never able to detect an audible difference between a balanced or single analog input. I could never with my RSA F-35 Lightning, balanced output yes, balanced input no.
The downfall with the kse 1500 is how uncomfortable they are to wear due to the housing.
??? For me the KSE1500 are the most confortable IEMs I have ever used !. I use a 3 flange tip.The downfall with the kse 1500 is how uncomfortable they are to wear due to the housing.
