Hoping to get some advice on what can be done to fix my M1, as like some other posters have described, my scroll wheel has also broken after not much use.
The wheel itself has actually detached from the body, and as you can see in the photo, there seems to be a plastic sleeve (which holds the wheel in place), that has split in several places. I assume this is from the pressure of the click component of the wheel? The strange part is I've used it no more than a dozen times, and it's never been dropped.
I'm not sure what unscrewing the screw shown will achieve, if anything. Can it be repaired? Happy to send it back to @Shanling if something can be done, as I really like the player and want to try and fix it.
So sad this happened to your M1
With faults like this, your first step should be contacting the shop you purchased it from, it's firstly their responsibility to cover warranty.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
