Stick a small piece of foam in the middle of the headband to relieve the pressure.
Philips A5-PRO "Armin Van Buuren Collaboration" (Owners and impressions)
- Thread starter cb3723
VRacer-111
Do you have photos of the 9500 b/c mine looks nothing like stock anymore, and ofc i have the headband issue. How did you fix this? Which leather strap.
As for top of head pressure i've felt on other cans, and sometimes breaking in helps, or i have used hairdryer to accelerate break in, which worked on a beyer i have with the ultrasone headband notorious for that same type annoyance
I bought the MrSpeakers Comfort Leather head strap for the Fostex TXXRP and modified it:
Modded MrSpeakers comfort leather strap
...on the SHP9500...
...with the 1840 pads...
The 1840 pads have the foam removed from the back of the driver covering fabric and a layer of tissue paper to help tame the highs. The 1540 pads absolutely had to have the foam removed otherwise the sound was too veiled and slightly too dark sounding. The 1840 pads may be fine with the foam left in, I immediately defoamed them before putting them on based on experience with the 1540 pads.
CoFire
- Dec 5, 2015
Can anybody compare the A5 Pro to the HD25 II or Amperior?
Own the Amperior, HD25 and the A5 Pro.
A5 is much better in everything and built like a tank.
thekrautdog
- Sep 27, 2012
Tank is damn right (thumbs up). Certainly wish they were lighter but life is full of these little tradeoffs :^)
The best part is the pitch black background of the drivers.
Really high quality stuff there, my third Philips after the L2 and the O'Neil and my second pair of A5s.
CoFire
- Dec 5, 2015
I like them, just not sure why they never gained popularity. I still need to find a head band cushion. They are a brutal with that pressure point right on the top of your skull.
So after having the A5's a few weeks I can reiterate that I LOVE these cans. Listen to them almost every day. Definitely the best $80 I've ever spent in audio.
isaacy
- Jan 18, 2017
Ah, I can't seem to add an image to my post.
The error message says: Your account does not have the required permissions to access this page.
Does anybody know how to solve this problem?
Basically, I'm trying to post pictures that show how the black fabric of my stock ear cushions are tearing.
It's quite bad, and without a chance to buy replacement ear cushions, I'm just going to have to live with my torn ones. :/
Hi 5
- Dec 19, 2014
Read the top section in blue: http://www.head-fi.org/f/5620/feedback-bug-reports
"Due to issues with spammers, new Members cannot edit their profile or avatar or upload pictures immediately. Also, posts from new members may be automatically held for moderation. After you've been a member for a few days and made a few posts, your account will be automatically upgraded. Please do not attempt to re-post if this happens."
Welcome to the Forum
Hi 5
- Dec 19, 2014
Awesome!!
I'm still blown away by that sweet deal =)
GouryellaIV
- Nov 5, 2015
Post the images in Imgur.
How long have you had your headphones? Ive have them for over a year and the cushions are in excellent condition even when i use them daily
bar1
- Jul 4, 2008
Good news for X2 and A5-PRO owners in Scandinavia (+Finland).
Philips spare part company in Sweden have the big velour ear pads for X2 and A5-PRO.
X2:
left ear: https://www.reservex.se/artiklar.asp?id=65230
right ear: https://www.reservex.se/artiklar.asp?id=65231
A5-PRO:
https://www.reservex.se/artiklar.asp?id=64556
They will ship to Denmark, Norway and Finland (except Åland).
X2:
A5-PRO:
rlisin
- Jan 20, 2017
No shipping to the rest of Europe? Pity.
Oh well, good thing I managed to buy one of the last 80 mm pads from Armada. At least I have something for when the stock ones fall apart. And then I will certainly try to harvest the mounting mechanism and see if there's a way to attach non-Philips pads to it.
I noticed that some Chinese headphones use similar pad mechanism, for example Meizu HD50 and Xiaomi Mi. I wonder if one of these made the mechanism for Philips.
CoFire
- Dec 5, 2015
That would be awesome if anyone can confirm if these pad mounts are compatible. More so if they can provide some sources for buying the pads. I've never heard of these Chinese headphones so without buying a sacrificial set, I have no way to confirm.
