b0bb
- Oct 15, 2014
I'm waiting on the FIFO and clock boards from Ian here: https://github.com/iancanada/DocumentDownload and I have one of the new XMOS boards to use just for the USB input (it seems to have a better Linux DSD native support than Amanero) http://www.diyinhk.com/shop/audio-kits/107-xmos-dsd-dxd-768khz-high-quality-usb-to-i2sdsd-pcb.html but I was thinking of feeding the output from the above via the I2S Ethernet input of the 004.
If I understand correctly, I should do it via the Amanero header instead?
Looked at those a while back, Ian's board did not support DSD, the upcoming v2 does. I dislike having to change sources just to play PCM vs DSD.
The work goes beyond wiring it into the I2S header. You still have to deal with clock sync problems as there 2 clocks in the I2S stream, this is something the got Singxer wrapped around the axle with the clicks and bangs. Talk to @abartels if you want to find out how things can go south with Ian's board, he used it on the AKM dac.
The reclocker in the 9038 cannot be bypassed in the LKS, so most of work reclocking at the I2S side is wasted.
You end up with 2 reclockers in series, one in Ian's board and the other in the 9038, if the Singxer F-1 with on board reclocker is any indication, this is not a happy state of affairs.
It remains to be seen if the reclocker in Ian's FPGA can do a better job than the ESS one in the 9038.
I would toss the 575 controlling the reclocker on the 9038 and replace it with and ovenized XO (OCXO), I used 2 different OCXOs on the 003 and its on my todo list for the 004
One small saving grace for Amanero is that it now has an in-kernel Linux driver.
(If you really want to experiment to see what Ian's FIFO board is truly capable of, get one of the eval boards from DIYINHK and run it in sync mode to disable the 9038 reclocker.
The LKS 004 is hardstrapped in async mode and is ill suited for the purpose.
With the eval board you can experiment with the various USB interfaces out there, it is a lot cheaper if you make a mistake, 2 people have damaged their 003s here, one recovered, the other did not.
http://www.diyinhk.com/shop/audio-k...t-perfect-volume-control-and-spdif-input.html)
