mb3
- Apr 30, 2007
Info about the ess9038pro chip filter settings.
That looks good a bit more metal than the one I used.I found this mod worked well for me - placing one heatsink across two transistors. The unit is now significantly cooler. see https://www.jaycar.com.au/to-220-clip-on-heatsink-6043-type/p/HH8503
What did you do with the snap-on ridges on the flat side? It looks like those would greatly reduce the contact surface.yes they were pretty good - and also insulated so no problem with shorting
I just used a flat head screw driver and fine pliers to flatten out the ridges - I then put a little kapton tape to cover that side of the heat sink.What did you do with the snap-on ridges on the flat side? It looks like those would greatly reduce the contact surface.
Hi b0bb (and others)
Any further modding to the 004 to report?
I have been out of the loop for a good while due to bad health, but I hope to get a soldering iron back in my hand in the next couple of months.
pat
Hi b0bb,
Ever tried ultracaps? Maybe take a look at this thread, it's very interesting.
https://www.head-fi.org/f/threads/r2r-da-m1-ultracap-powered-build.839007/page-4#post-13466545
I have a Kali reclocker powered with ultracaps, and my AK4495 now also has all it's voltagerails (6x) powered by ultracaps.
Those psu's are LDO-free design, just needs careful calculation of runtime ultracaps to stay between voltage tresholds.
This gives us a pure DC supply which in my opinion outperforms EVERY conventional psu design.
These designs have lots of relay switching (for my dac 26 relays each ten minutes), but switching noise can be kept to a minimum within enclosure with little damping.
Since loading circuit is galvanic isolated from running circuit, there's no need to take care of clean power to feed and charge the modules, a laptop adapter is all you need.
Soundwise, how do those ultracaps perform? You have to listen to them to believe it. It just combines the best of the best of both worlds (analog & digital).
Since I first started to use them in psu for my Kali reclocker, I allready was convinced I wouldn't go back to LT3042 with R-Core and EMI/RFI filtering.
Since powering my whole dac, eh, networkstreamer it should be called, with ultracaps, I never COULD go back to conventional linear psu's, that's for sure.
Sad thing is, if I wanted to power my pre-amp with ultracaps in an audiophile manner, I would need at least 96 BIG ultracaps (350F Maxwell - D-Cell format), which would result
in an external enclosure of 430mmx120mmx410mm (lxhxd). But I am really thinking on building this in the future.
Just give it a try b0bb, you will be VERY pleased, promised
Cheers,
Alex
The stock 004 is quite good, SQ wise several notches above the 003, even my modded one, it has caused a degree of complacency
I am almost done with house remodelling which has been taking almost all of my freetime. This is almost done so I will have time later in the year to add the OCXO
One of the things I added in the remodel are new dimmers for LED lighting which use reverse phase dimming aka IGBT dimmers.
Until LED lamps showed up, these were in the 4 figure price range used in stage and theater lighting.
These put out a lot less RFI compared to the older SCR or Triac dimmers,and therefore less RFI junk in the house wiring.
The 004 SQ went up by half a notch which was unexpected.
The 004 seems very sensitive to RFI, I already have 2 RFI filters in line going to the DAC in addition to the RFI filter on the old Triac dimmer.
