Little Dot Tube Amps: Vacuum Tube Rolling Guide
Jul 21, 2017 at 11:25 AM Post #11,117 of 13,434
Hi guys,
Now, I got really confused.
I was searching through ebay, and I did find the 6AK5, but it says, 6AK5 EF95, so, if this is a EF95, then I don't need any adapter, as its just plug in, my Little Dot MK II is compatible with the E95, the 6J1P-EV I'm using now are EF95.
So, is ebay wrong, is it me, or is both of us. Or none. lol
Cheers,
Jul 21, 2017 at 11:45 AM Post #11,118 of 13,434
The Radio Museum site can be very helpful in determining equivalents:
http://www.radiomuseum.org/tubes/tube_6ak5.html
Identical to 6AK5 = EF95 = 6Ж1П = 6069 = 6F32V = 6F32 = 403A = 731A = PM05
Similar Tubes
Other shape (e.g. bulb type):
CK604A
Normally replaceable-slightly different:
6AK5A-TS ; 6J1
Other class quality (otherwise equal):
5654 ; 6AK5W ; 6J1-Q ; CV850 ; GL-5654 ; M8100
I am not sure what tube you are referring to, but you can run any of the above tubes using the EF95 setting, without adapters.
If you are talking about the C3g, compared to the EF95/6AK5, it has a different base and different connections and definitely requires an adapter. However, with an adapter it is pin compatible with the EF95.
Jul 21, 2017 at 3:23 PM Post #11,119 of 13,434
Similar Tubes
CK604A
6AK5A-TS ; 6J1
Thank you gibosi !
I think I was confused with the references. ( noob alert ! ) lol
Ill dig a lot more, and take a look at the link you just posted.
Cheers :)
Aug 8, 2017 at 3:00 PM Post #11,123 of 13,434
[size=18.0pt]5. CONCLUSION[/size]
5.1 Can’t Decide Which Tube to Buy?
To Little Dot’s credit, their Mk-series amps have an impressive number of tube rolling options and there are more than a few very informative threads dedicated to this topic. I would recommend anybody interested in upgrading their stock tubes to take advantage of our collective knowledge and take a look at those threads. Occasionally I have received PMs from new members who are overwhelmed by the sheer number of tube rolling options, and asked for my recommendations so they can stop reading forums and get back to listening to their music. So here’s my short list: I would recommend the Voshkod 6ZH1P-EV as the best place to start as it is a clear upgrade from the stock tubes, followed by the Mullard M8083 for its impressive treble clarity and top-octave ‘air’ (provided you have matched power tubes). The RCA 5654 (black plate) is also a wonderful option for its solid all-around performance, great bass response and availability.
5.2 Tube Sellers
I’m very picky about whom I purchase my tubes from, particularly about how they match and test their tubes as well as warranty periods. The following is a quick list of tube sellers that I have personally dealt with and have been happy with. There are certainly many more just a Google search away.
Yen Audio
TubeDepot
VacuumTubes.net
Thetubestore.com
5.3 Useful Links
Intro to Tubes: http://www.head-fi.org/forums/f5/new-improved-tube-faq-newbies-119389/
Little Dot Official Site: www.littledot.net
Official Little Dot Dealer: http://shop.ebay.com/davidzhezhe/m.html?_trksid=p4340.l2562
Version History:
1.0 - 07/22/2011 - original post
I have just replaced the chinese junk drivers on my LD mk2 for the Jan5654w Drivers, what a great difference in sound. However i am a little confuse on the power tube, which do you recommend?
Aug 9, 2017 at 9:40 PM Post #11,124 of 13,434
Aug 9, 2017 at 10:09 PM Post #11,125 of 13,434
QUOTE="Tony51, post: 13648385, member: 425917"]I have just replaced the chinese junk drivers on my LD mk2 for the Jan5654w Drivers, what a great difference in sound. However i am a little confuse on the power tube, which do you recommend?[/QUOTE]
These power tubes were very popular http://www.ebay.com/itm/6N6P-IR-ECC...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649 Also power tube reviews page 201 post 3007 of thid thread
Aug 26, 2017 at 6:15 PM Post #11,126 of 13,434
Recently purchased a Little Dot MKIII through Massdrop and have been experimenting with various tubes--from suggestions from this thread. A big thank you for all the contributors--I have no clue about this stuff and am happy to get any advice.
I have a set of Fostex TH 900 with the Silver Dragon cord from Moon Audio--hoping to tamp down the excessive high end.
Really want to know if there is a good tube to match to these headphones that will tame the high end--
I really love the bass and sound of these headphones but---damn, the high end can get really piercing and frankly unlistenable with certain tracks.
If anyone has any knowledge and experience with this I would be grateful for any advice--
thanks!
Aug 26, 2017 at 10:45 PM Post #11,128 of 13,434
Try to use EQ instead of tube rolling,Tube rolling can get expensive(at least for me).
Good advice--
I use EQ when I am playing tracks on my AK 120 II--plugged into the Little Dot.
I recently bought a stand alone Tascam cd player and have it plugged in directly to the Little Dot.
I just ordered a Behringer FBQ1502HD EQ--that should do the trick.
Aug 28, 2017 at 11:26 AM Post #11,129 of 13,434
(Mods, if this is in the wrong place, please let me know)
LDMKIV tube rolling question from a newbie.
Bought my first tube to roll with: a pair of Mesa Boogie EL84/6BQ5s, recommended by a local dealer. They aren't working right: there's hardly any sound, just horrible static.
They are seated correctly, and I have de-oxidised the pins. They do not appear to be damaged or dead (silver top, no purple glow etc), and I bought them from a reputable dealer. Stock tubes working fine, with good sound, so it's not the amp itself. Before I send them back: it occurs to me that I may need to change the jumper switches. But I don't know what these look like, and Google is no help. Neither unfortunately is the LD manual/reference guide.
Do I need to change the jumper switches? If so, where are they? And please don't say 'next to the capacitors' - assume I'm an idiot please! Muchas gracias
