flyte3333
Previously known as Em2016
- Jan 21, 2017
The one thing those devices should do is sound like they are not there.
Well said ! So true
Thanks for the suggestion. I'm testing your theory to see if you are in fact correct.
I think it depends on you DAP. Different DAP has different implementation. I know DP-X1 will not work this way.Does anyone know if you can use Poweramp as a music player when listening through USB to the Micro BL? I've found a great remote control app which allows me to browse and play files through Poweramp via my Smartwatch.
Ok, so I've just found out my main phone, Xperia xa, won't work with the BL at all, even using UAPP. Thankfully I have other devices which will work, but it is frustrating. If it's advertised to work with android, then it should on every android device, and also without having to resort to spending extra on special apps.
Dodgy to say the least.
Thanks for the response.The fault here is not with the iDSD...it's with you phone. Not all Android have the USB-host functionality. Luckily for you the XA does have it. Did you perhaps recently do a software update? It's likely that you'll need to go into the settings and enable USB audio
Any idea how to do this on the xa? I've tried a few settings in developer options with no success.
I have an iFi IDSD Micro that will not charge. I have tried the iFi suggested power cycles without success.
I have already paid for one out of warranty repair and the Canadian authorized depot that did the repair for me last time, suggests that it would not be economical to repair and offered me a discount of $50 off the new version.
I am wondering if the battery is easily sourced and replaced, and if anyone has done this?
Woah
What happened?
You kept it charging for all the time you used it?
The batteries should be possible to replace, but like any product, one you open it, you might lose the warranty.
@iFi audio might have some advice or a series for the battery to help you out, but I am curious why the battery stopped charging since mine has been used daily and doesn't show a single sign of usage.
I have reached out to iFi. It did completely discharge. It was plugged into a usb hub that was inadvertently unplugged and I hadn't used it in several weeks.
Ifi suggested using the blue usb cable included and following a cycle of charge for 2 hours, unplug, repeat, which didn't help.
Just rapidly flashes Blue. Unit is out of warranty and already had to replace the main board in an out of warranty repair.
