b0bb
- Oct 15, 2014
New to posting here. I may have missed it but does the x20 Pro have op amps in it that can be changed to something like Burson discrete op amps? Thanks.
The I/V opamps can be changed. You will need the right SMT rework equipment and the adapter below.
http://www.logicalsys.com/painfo-vpasp-vb.asp?adapter=pa-dso-0803-d250-08/2
When replacing the I/V opamp the input impedance of the opamp has to be matched to the output impedance of the ES9028/9018 output and its surrounding components, this is implementation dependent.
In the case of the Gustard, the existing I/V opamp has a bipolar transistor input, the Burson V5, for example, uses a JFET so you may end up with less optimal results as the input impedance at high frequencies is lower due to the higher input capacitance of a JFET input.
(JFETS have very high input resistance at DC but at high frequencies the input capacitance lowers this).
