myemaildw
- Jun 10, 2014
Anyone has a broken set of the drivers? even just broken replaced driver ? I actually bought fa stainless set
I've just discovered how tuneable the R2As are. Since I got them shelled I've been grabbing the tops of them to twist into my ears so they sit and seal correctly. Over time I've lost bass and wondered if it was my hearing or the Flares just deteriorating. I also noticed that bass balance had drifted towards my left ear.
Before putting them in tonight I had a look at them and saw that the gap between the cap and the body was much smaller on the right side than the left side. Thinking back to a post made by James444 a while ago I matched the gaps by unscrewing the right hand cap. Voila! Bass is back in a big way. What has been happening is that by rotating the iems slightly in my right ear to get a good seal I have been gradually been tightening the right hand cap - and therefore reducing the bass!
With the shells in my ears I can unwind or wind up the caps in situ and therefore tune the bass to my liking. Well done Flare on having an inifnitely tuneable iem. Makes the dial on the IE80 look very primitive indeed
Not sure if that was their original intent, but it does work
Does anyone know where can I buy a new cable for the R2 pro, I broke the it again with 4 months!
But Flare are not selling the replacement cable on amazon uk anymore, either the official website!
Where did it break? If it's near the plug it might be easier to find someone who can solder a new plug.
