holden4th
No I don't think the R2 is totally sealed either. I can unscrew the back of my R2A and as I do it alters the bass.
Looking forward to the closed model! Hope the KS starts soon
First page says the entry level one is closed.Maybe it's not far away. You can no longer buy any of the R2 series from Flare's website.
I don't have problems removing the Flare Audio R2Pro from my ears. Guess it depends on how far they are inserted. They don't need to be inserted that deeply.
The Flare are supplied with Comply foam tips. This model Comply has wax guards built in. If you use other tips, there is still 4-5mm of space between front of tip and Flare enclosure. Just monitor it and pop the tips off to clean them.
There are other microdriver IEMs. Believe the Aurisonics fall into that category. Friends that have both tell me the Flare sound better.
Hi everyone, A few quick questions since we are all waiting anyway...
I have some (rather soft so nice) earplugs that are really small they cant get stuck in your ear since they are custom BUT they are EXTREMELY hard in my opinion to get out anyway perhaps i have small earcanals and thick fingers. How is this with the flare models?
Secondly i read earlier in this thread that there are no filters to protect against earwax and that the sleeves are open, will this not affect their durability?
And third are these the only very tiny very comfortable iems out there at the moment?
I have owned a lot of iems in the past but a lot of them stick out too much or are not durable enough for use with sleeping.
Thanks in advance for any info,
Greetings, Anouk,
My recommendation for sleeping are the Trinity Hyperion. With the discount for headfiers (search for it on bob trinity's signature at they crazy, infuriating forum... i got tired of it...), they are the greatest budget in the iem world. They are even smaller than the Flares and great sounding also. Obviously i prefer the Flares sound, but i'm not so confident about their durability and at the low volume i use for sleeping sound differences attenuate a lot. For their price (about 18€) it's too cheap to try... i find it difficult to regret about it, but hey, just my personal experience...
In fact i still recommend the Flares as the best tiny iem i've tried, but for other uses
