FLAC vs CD quality difference
Sep 23, 2012 at 6:50 PM Thread Starter Post #1 of 22
barksdale
Is there a quality difference between FLAC and actual CD?  Should it be the same or no?
CD is 128kbps but if you upconvert to FLAC you would lose quality even though you are going to loseless codec.
Sep 23, 2012 at 7:13 PM Post #3 of 22
FLAC files are generally ripped from CDs. They are "lossless," which means no data is lost from the digital files on the CD. In other words, the quality should be about identical. A 128 bit rate is far from CD quality, but some untrained ears might not be able to tell the difference.
Sep 23, 2012 at 8:19 PM Post #5 of 22
No.
Some ripping software will claim that 128kbps is "CD Quality" (maybe that is where you are getting this idea from?), but it most certainly is not. Think of it this way: if you put a CD into your computer and look at the individual song files, you'll find that a 4 minute song will be about 50 megabytes; the same song with a 128kbps bit rate would be about 5 megabytes. That means there is 10x more data on the CD file. A FLAC rip of the file on the CD would be pretty near the 50 megabytes on the CD, because it loses no data, is not compressed, hence "lossless." MP3 files DO lose data, they ARE compressed, they are "lossy."
Now, if you are listening to music through entry-level earphones or small computer speakers you probably won't be able to tell the difference either way...
MP3 files are very high quality for the size of the files and perfectly practical when you are on-the-go. If you want to get the best quality MP3s from your CDs, you should rip them at 320kbps - the file sizes will still be drastically smaller than lossless files, so you'll be able to fit much more music on your mp3 player.
Sep 23, 2012 at 8:30 PM Post #6 of 22
I thought most CDs were 128kbps.
What are you guys ripping with, dbpoweramp and encoding with LAME eac?
CDs are 1411kbps.
I usually rip with EAC since it ensures an error free rip.
No.
FLAC files actually are compressed. If you want uncompressed, that's wav.
But the way FLAC compresses it doesn't lose any data, it just needs to be interpreted in a certain way.
An example of how losless compression would work:
Original Data: aaaaaaabcdeeeefg
Compressed Data: !7abcd!4efg
While the compressed data isn't as large of an amount of data, the program will know that ![n] means to repeat the character a certain amount of times so that it appears the exact same way as the original data.
Sep 23, 2012 at 9:50 PM Post #7 of 22
Thanks for the info.
I have pretty decent headphones and I can hear a big difference between 320kbps and 128kbps.  256 VBR and 320kbps not so much.
I need to rip some stuff FLAC and compare.
So everyone uses dbpoweramp still?  that program is old but I guess it still does the job!
Sep 23, 2012 at 10:02 PM Post #8 of 22
CDs are 1411kbps.
But you see chewy that is where things get tricky. While I agree no data is lost if the compression if done properly. The problems appear when the file is being unzipped on the fly with most programs and even on DAPs in general. I've found using cPlay in bit for bit with my DACport LX there is a noticeable difference between other programs that I use (J River, Media Monkey Gold, Foobar). What cPlay does is it properly unzips the file then stores it in memory cache before music playback and not doing it all on the fly. So its playing back a WAV file as it was intended. I notice improvements in the sound staging, and especially in the treble region. Its enough for me to be tempted to unzip my FLAC files on my Studio V and even DX100. But won't do so until memory capacity increases more and prices go down more :).
Sep 23, 2012 at 10:19 PM Post #9 of 22
try the different players in a blind ABX - what you are describing is literally impossible.  if the decompression were failing, you wouldn't hear improvements in the treble, you'd hear major clipping and noise.
Sep 23, 2012 at 10:23 PM Post #10 of 22
That's my point. I've noticed situations such as this even on my Studio V with certain FLAC files (clipping) where it is a none issue in WAV form. I have done blind testing before and I still prefer cPlay. I just notice more detail in the songs with it (some are more apparent then others). Not sure why but I'm gonna stick with it. It's a bit of a hassle to have to manually pick each song but for musical enjoyment I feel it's well worth it. The only logical reason I could come up with for these differences is due to the programs decompressing the songs and doing something wrong in the process of doing it.
Sep 23, 2012 at 10:44 PM Post #11 of 22
I've never had a problem with the buffer not keeping up. I can see how it could happen but it's never really happened to me before.
Like Doug said it wouldn't be a subtle difference if something was going wrong. But if you think it sounds better in a different player than more power to you.
I'm curious of what your methods of blind testing were though.
Sep 23, 2012 at 10:46 PM Post #12 of 22
My cousin was going back and forward between the players. We volume matched them before starting the test and I selected tracks that I am very familiar with and picked out the differences quite easily. Not only have I noticed inconsistencies between cPlay and the other players. The other players seem to have their own differences as well to the sound. Its bizzare and slight but noticeable. I actually prefer Media Monkey Gold because it has a very nice emphasis on the mid-range. J River and Foobar are sound about the same though. Everything is more distant, more blended in I guess (you could say more balanced).
May 7, 2016 at 10:42 PM Post #14 of 22
Hello, I think this may answer your question once and for all.
FLAC is a lossless format, designed to sore audio indormation that involves algorithms to reduce storage space. This means a program reading a FLAC will be able to uncompress without any information loss. Aditionally the upper limit sample rate and resoloution of FLAC is 655,350 Hz and 32 bits. A CD uses PCM a method of information storage that is uncompressed, note that greater sample rate and resolution requires extensively more space to store it. This is evident in CDs that all store information in a sample rate and resolution of 44100Hz and 16bit.
WAV is actually a bitstream encoding container used to typicly store LPCM (a format under PCM)
So in summary, if you use FLAC to store your existing CD format, you will lose not information in comparison. However FLAC can be used to store higher sample rate and resolution with less space than an uncompressed format. And the real limitation is finding audio originally recorded in a higher sample rate and resolution, or in a non digital format that can be converted.
Jul 26, 2016 at 8:55 AM Post #15 of 22
Hello I am always conf with all this they said before flac was the format all I want is is to rip  my cds on computer to recorded it in the best possible  closest to the cd original  in every way I was told flac was it I needed and had a special quality that gave space in recording when in flac to hear more of the music I just go round in circles what is he best  format  you seem you might know thanks for your time
