WindowsX
Member of the Trade: Fidelizer Audio
- Apr 27, 2007
Yesterday I borrowed Fiio X5iii from my friend's shop to test. It sounded so freaking to the point whether it needs ROM modification as many spoke of. After flashing 1.1.4 OTA. I immediately realized how worse sound quality is. I'm not surprised why many people went back to older 1.1.1 ROM.
Luckily, I peeked on my friend's unit before and it was 1.0.9 so I compared sound quality between 1.0.9 and 1.1.1. 1.0.9 sounded so much better. So, here's my Fiio X5iii Purist mod to improve sound quality for free.
-Remixed firmware using 1.1.1 kernel which is the best sounding kernel from Fiio without wake lock issue repacked with 1.1.6 files
-Deodexed
-Apollo - Fidelity Edition from https://forum.xda-developers.com/android/apps-games/apollo-music-player-fidelity-edition-t3038629 included
-build.prop tweaks for better video and storage performance and improve battery life
-bundled audio effects removed but keep main engine (Poweramp works now)
Download: http://www.mediafire.com/file/d6pax82vo0w6jhj/X5iii-1.1.6-WindowsX-Purist.zip
Installation Guide
1. Download Factory Tool provided by Devin http://www.mediafire.com/file/0yztdw6qdpwwp9a/X5III+Firmware+Upgrade+Tool+with+FW1.1.1.zip
2. Turn off Fiio X5iii
3. Connect X5iii with USB connection to computer while holding previous track button
4. Install RK USB driver included in Firmware Upgrade Tool and replace update.img image with mine.
5. Open X5III Firmware Upgrade Tool.exe and flash ROM according to instructions provided in Instructions of How to Use the X5 3rd gen Firwmare Upgrade Tool.pdf
Since many people asked for Poweramp fix before, I decided to lower the bar by not removing audio effect engine completely like true purist ROMs in past. That's as far as I can do to keep up with compatibility request.
Many thanks to Fiio team for providing firmware upgrade tool. I hope you guys will enjoy this ROM.
If you have any question about the ROM to ask personally, please use my E-Mail address lucifiar@hotmail.com instead of PM for faster response.
Regards,
Keetakawee
-Deodexed
Installation Guide
Regards,
Keetakawee
