Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
Jul 27, 2017 at 11:17 AM Post #10,441 of 15,899
@FiiO please make me understand the audio_policy.conf located at home/etc
Why is 24 bit PCM missing and output fixed at 48 kHz
Jul 28, 2017 at 4:55 AM Post #10,444 of 15,899
http://m.fiio.net/en/stories/576
The following changes and improvements have been made to the FW1.1.7 compared to the FW1.1.6
1. Added a new theme for FiiO Music (can be set in FiiO Music->Setting->Theme);
2. Added function to change the play order of the Now Playing list by dragging a track and moving it up or down (the order change will take effect for only once);
3. Added function to uninstall the Google service framework (go to "Settings->About device" and tap 7 times on the "Device name");
4. Improved the media lib auto-update in FiiO Music;
5. Fixed issue where a track could not be fast-forwarded to the end by dragging on the play progress bar;
6. Fixed issue where FiiO Music would exit abnormally after clicking the play button beside an artist then clicking into it;
7. Fixed issue where the total number of tracks would be mistakenly displayed as zero after returning to the root directory from a subfolder in Browse Files menu;
8. Fixed issue where FiiO Music needed to be opened with multiple clicks after it's closed by force;
9. Fixed issue where FiiO Music might exit abnormally when playing some tracks of unsupported formats;
10. Fixed issue where the play progress was displayed incorrectly in the Now Playing menu after pausing a CUE track;
11. Fixed issue where some single-channel tracks were played incorrectly;
12. Improved issue where some tracks could not be played;
13. Improved issue where some track titles were displayed incorrectly;
14. Improved the random play of an entire folder;
15. Miscellaneous bug fixes.
Jul 28, 2017 at 5:31 AM Post #10,445 of 15,899
@FiiO : great addition for minimize power consumption, but it would be great if you add a function to re-install it, no? In case of trouble, how to install again the Google service framework, please ?
Thanks!!
Jul 28, 2017 at 5:47 AM Post #10,446 of 15,899
New theme
I see some changes in the audio policy wherein some codes for alsa usb is added. Can anyone please check if the usb functionality is a go with this FW?
Jul 28, 2017 at 6:37 AM Post #10,447 of 15,899
Jul 28, 2017 at 7:12 AM Post #10,449 of 15,899
All I have is the Fiio E17 and no USB out. It shows Locked but no output.
To the Mojo I get USB audio out, but it's still re-sampling everything to 48kHz. Coaxial out still has awful hiss with files that are 5000-5500 Kbps and above.
Almost ready to sell this thing as the one reason I bought it, a source with no re-sampling USB audio out, and a functioning coaxial for all my tracks (even those that are 24/192 - like every other coaxial out), is still not working. For me the SQ isn't worth keeping the X5iii if FiiO can't get a proper coaxial output or deliver on the promised no re-sampling.
I hope it's not too long for them to find a solution as I know they've been working on it, but.....
Jul 28, 2017 at 7:52 AM Post #10,451 of 15,899
I like the new theme. I wonder if the blue and black theme will be updated to the new look.
They havent been updated with this FW update. Its the same cluster of buttons however the colours maybe cleaner on the blue and black theme.
Jul 28, 2017 at 10:28 AM Post #10,452 of 15,899
Sold mine last week. Gonna get a reliable iPod touch 128gb filled with Tidal Hifi going to Audeze isine20 with cipher cable. Good luck with yours Relic!
Jul 28, 2017 at 1:51 PM Post #10,455 of 15,899
  • Back
