TomNC
Thanks for your votes of confidence in the Elise. I plan to put my LD III on sale this weekend and keep the C3gs tubes that I like a lot.
Good luck with that, UT...I notice he's at it again - no listing of measurements in the text...but "on the white labels", one of which it is impossible to see the all-important plate mA figures...NAUGHTY, in my book lol! (100% rating?...hmmmm....).
True H1 but I won't commend anymore on the seller until the final outcome. One thing I learn from this is it pays to buy NOS when it comes to good tubes like the ECC31 / 32. My experience with the 5998 has taught me that. I bought 2 sets of 5998. The new pair is just incredibly new haha.
So I'm determined to hunt down a pair of NOS ECC31 that tested well with no physical impairments even if I have to go to Mars to get it.
Just heard from Lukasz that my Elise should be less than 2 weeks. Yeehaa.
Hi Mordy I really like how the 6N23P rockets sounded in my DV. I'll try it out in the Elise and let you know if it hums or sings I'm really hoping the latter because it's still cheap compared to premium 6922 or ECC88.
It's simple, M...get yourself an Elise, stick in 2x ECC31s or my 31/FDD20 combo, and join us up in the clouds lol!!
Hello blckmag,Hello to everybody,
I don' t want to steal the thread, but I don' t think it' s necessary to make another topic out of it.
My gear: Laptop --> Violectric v800 --> Elise --> Beyer T1
I hear a scratching noise in the left channel, just like there' s a weak cable connection. Connected the headphones directly to the laptop and there are no such problems.
I followed a advice to turn on first the amp for 5 minutes and then to plug in the headsets. Did that, and after that, I have this scratching noise.
So, I know the headset is not the issue. Could I be something from the connector adapter, maybe from the Elise (bad connection, bad tube(s) ) , DAC?
Any suggestions or quick fixes?
Thanks!
Hello blckmag,
Since you have the Elise in the chain, I would check the vacuum tube connections and the tube pins. Shut off the amp, let it cool down for a couple of minutes (to discharge capacitors) and then switch one tube at a time right/left. If the right channel now makes noise you know it is the tube. (Only pull out tubes by the base; not the glass part.)
Once you find the offending tube, gently scrape the pins with a pen knife, scissors etc (does not have to be sharp) and reinsert. If one tube with clean pins and good contact continues to make noise, leave it on for several hours - maybe burning it in will make it behave better.
If these things don't work you will have to replace the tube.
The above is only trouble shooting for tubes - could be other things as well. Just check all connections......
@blckmag keep us in the loop on your 'scratching' issue. Is it akin to a subtle rustling of paper sound through one channel? If so, the same happened to me.
My Elise is currently on the bench table of Feliks Audio for a health checkup for the same issue, i.e. scratching noise on the right channel. Still in warranty, so anything needing fixing will probably be fixed!
If it’s not the tubes then I’d suggest you contact FA for a similar arrangement.
