1clearhead
- Apr 5, 2013
...."slow and fall down carefully"Chinglish perfection:
Wow, the last phrase hurts just reading it.
I had these before, but with the adjustable vents only! ....It's interesting now they added filters to them.Anyone has any idea about this QKZ KD1 ?
2017 New Original QKZ KD1 In Ear Earphone HIFI fone de ouvido auriculares audifonos gaming headset fones de ouvido Earphones
http://s.aliexpress.com/zyuqaae2
(from AliExpress Android)
Looks interesting with the filter and adjustable vent.
It was just an okay fit for me. But, I might just reconsider and get them again if several reviews comes out positive because of the interchangeable filters.How was the fit and comfort?
I like the sound of titanium single dynamics, so I would expect this to sound really good.
There's nothing worse than having a great sounding headphone that fits like crap or is uncomfortable to wear. We've all been there, and it ends up gathering dust in the bottom of a drawer.
Sony MH1c...
Can somebody please repost instructions on how to remove the memory wire from the zs5 cable?
got it--for the uninitiated there's a silver wire (similar to but thinner than a paper clip) under the black sheathing over the top of the cable--you can use your fingernail to get to the silver wire, then zip up; remove the silver wire and then pull of the blcak sheathing. takes less than a minute and makes a big difference in comfort and esp. fitmentYou basically grab the wire and 'zip' it out like you're pulling on a zipper (the wire tears through the soft tubing). Once the wire is totally removed, you grab what's left of the tubing and pull that off the rest of the way using the same "zipper" action.
If you have trouble getting to the wire to get started, you can CAREFULLY trim through the tubing using nail clippers (finger/toe) or scissors (with a side cutting action; cutting the outside of the tubing vertically), being CRAZY careful not to cut into the actual earphone wire.
It's kind of hard to explain in writing, but very obvious once you actually do it.
Can someone recommend me a decent Bluetooth MMCX cable? There are plenty in Aliexpress, but have no idea which one to buy... It's for my Magaosi K3 Pro, and I want the SQ to be as good as the stock cables if possible.
Do the ones that cost $10 in Ali work at all? - https://www.aliexpress.com/item/New...-MMCX-upgrad-cable-For-Shure/32797103062.html
Penon are selling several, but the reviews are not that good (although not many) - http://penonaudio.com/index.php?route=product/search&search=mmcx bluetooth
There's a new one by Tennmak as well - https://www.aliexpress.com/store/pr...32820139923.html?spm=2114.12010615.0.0.fGkWlN
Thanks !
